Printer errors out with MINTEMP at startup when room cold.
Increasing room temp fixes, but at a co$t.
I don't think safe mode will fix this.
Complete Logs
Recv:  == T:13.70 /0.00 == B:13.18 /0.00 @:0 B@:0
Recv: echo:busy: processing
Recv:  == T:13.54 /0.00 == B:12.86 /0.00 @:0 B@:0
Recv:  == T:13.49 /0.00 == B:13.02 /0.00 @:0 B@:0
Recv:  == T:13.39 /0.00 == B:13.13 /0.00 @:0 B@:0
Recv:  == T:13.54 /0.00 == B:13.07 /0.00 @:0 B@:0
Recv:  == T:14.06 /0.00 == B:13.02 /0.00 @:0 B@:0
Recv:  == T:14.06 /0.00 == B:13.23 /0.00 @:0 B@:0
Recv:  == T:13.49 /0.00 == B:13.54 /0.00 @:0 B@:0
Recv:  == T:13.96 /0.00 == B:13.23 /0.00 @:0 B@:0
Recv:  == T:13.13 /0.00 == B:13.44 /0.00 @:0 B@:0
Recv:  == T:13.80 /0.00 == B:13.44 /0.00 @:0 B@:0
Recv:  == T:13.33 /0.00 == B:12.66 /0.00 @:0 B@:0
Recv:  == T:13.59 /0.00 == B:13.02 /0.00 @:0 B@:0
Recv:  == T:13.18 /0.00 == B:12.81 /0.00 @:0 B@:0
Recv:  == T:13.28 /0.00 == B:13.23 /0.00 @:0 B@:0
Recv:  == T:13.23 /0.00 == B:13.02 /0.00 @:0 B@:0
Recv:  == T:13.96 /0.00 == B:13.07 /0.00 @:0 B@:0
Recv: X:180.00 Y:180.00 Z:12.45 E:0.00 Count X:14400 Y:14400 Z:9960
Recv: ok
Send: G90
Recv: ok
Send: M113 S2
Recv: ok
Recv:  == T:13.70 /0.00 == B:12.92 /0.00 @:0 B@:0
Recv:  == T:13.49 /0.00 == B:12.86 /0.00 @:0 B@:0
Recv:  == T:13.75 /0.00 == B:13.07 /0.00 @:0 B@:0
Recv:  == T:13.65 /0.00 == B:13.13 /0.00 @:0 B@:0
Recv:  == T:13.28 /0.00 == B:12.76 /0.00 @:0 B@:0
Recv:  == T:13.49 /0.00 == B:12.71 /0.00 @:0 B@:0
Recv:  == T:13.59 /0.00 == B:12.86 /0.00 @:0 B@:0
Recv:  == T:13.59 /0.00 == B:12.97 /0.00 @:0 B@:0
Recv:  == T:13.39 /0.00 == B:12.55 /0.00 @:0 B@:0
Recv:  == T:13.59 /0.00 == B:13.07 /0.00 @:0 B@:0
Recv:  == T:13.33 /0.00 == B:12.97 /0.00 @:0 B@:0
Recv:  == T:13.23 /0.00 == B:12.66 /0.00 @:0 B@:0
Recv:  == T:13.39 /0.00 == B:12.92 /0.00 @:0 B@:0
Recv:  == T:13.23 /0.00 == B:12.71 /0.00 @:0 B@:0
Changing monitoring state from "Operational" to "Starting"
Send: N0 M110 N0*125
Recv: ok
Changing monitoring state from "Starting" to "Printing"
Send: N1 M140 S60*82
Recv: ok
Send: N2 M105*37
Recv: ok == T:12.92 /0.00 == B:12.60 /60.00 @:0 B@:0
Send: N3 M190 S60*93
Recv:  == T:12.92 /0.00 == B:12.60 /60.00 @:0 B@:0 W:?
Recv:  == T:13.49 /0.00 == B:13.18 /60.00 @:0 B@:0 W:?
Recv: Error:MINTEMP triggered, system stopped! Heater_ID: bed
Recv: Error:Printer halted. kill() called!
Changing monitoring state from "Printing" to "Error: MINTEMP triggered, system stopped! Heater_ID: bed - Printer halted. kill() called!"
Send: M112
Send: N4 M112*37
Send: N5 M104 T0 S0*36
Send: N6 M140 S0*99
Changing monitoring state from "Error: MINTEMP triggered, system stopped! Heater_ID: bed - Printer halted. kill() called!" to "Offline (Error: MINTEMP triggered, system stopped! Heater_ID: bed - Printer halted. kill() called!)"
Changing monitoring state from "Offline" to "Opening serial connection"
Connecting to port /dev/ttyUSB0, baudrate 115200
Changing monitoring state from "Opening serial connection" to "Connecting"
Connected to: Serial<id=0x6caed8d0, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Recv: start
Recv: echo: External Reset
Recv: Marlin Ver 1.70.1 BL
Recv:
Recv: echo: Last Updated: 2019-09-04 | Author: Ender-5 Plus
Recv: echo:Compiled: Sep  5 2019
Recv: echo: Free Memory: 1460  PlannerBufferBytes: 1232
Recv: echo:V41 stored settings retrieved (526 bytes; crc 41371)
Recv: echo:  G21    ; Units in mm
Recv: echo:  M149 C ; Units in Celsius
Recv:
Recv: echo:Filament settings: Disabled
Recv: echo:  M200 D1.75
Recv: echo:  M200 D0
Recv: echo:Steps per unit:
Recv: echo:  M92 X80.00 Y80.00 Z800.00 E93.00
Recv: echo:Maximum feedrates (units/s):
Recv: echo:  M203 X500.00 Y500.00 Z10.00 E50.00
Recv: echo:Maximum Acceleration (units/s2):
Recv: echo:  M201 X500 Y500 Z100 E5000
Recv: echo:Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel>
Recv: echo:  M204 P500.00 R1000.00 T500.00
Recv: echo:Advanced: S<min_feedrate> T<min_travel_feedrate> B<min_segment_time_ms> X<max_xy_jerk> Z<max_z_jerk> E<max_e_jerk>
Recv: echo:  M205 S0.00 T0.00 B20000 X8.00 Y8.00 Z0.40 E5.00
Recv: echo:Home offset:
Recv: echo:  M206 X0.00 Y0.00 Z0.00
Recv: echo:Auto Bed Leveling:
Recv: echo:  M420 S0 Z2.00
Recv: echo:PID settings:
Recv: echo:  M301 P14.72 I0.89 D61.22
Recv: echo:Z-Probe Offset (mm):
Recv: echo:  M851 Z-2.45
Recv: echo:SD init fail
Recv:
Recv: echo:  M200 D0
Recv: echo:enqueueing "M420 S1"
Recv: ***Initing card fails***
Recv: ===Initing RTS has finished===
Recv: echo:Bed Leveling On
Recv: echo:Fade Height 2.00
Recv: ok
Changing monitoring state from "Connecting" to "Operational"
Recv: ok
Recv: ok
Send: N1 M115*39
Recv: FIRMWARE_NAME:Marlin Ver 1.70.1 BL (Creality3D) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:Ender-5 Plus EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
Recv: Cap:EEPROM:1
Recv: Cap:AUTOREPORT_TEMP:1
Recv: Cap:PROGRESS:0
Recv: Cap:PRINT_JOB:1
Recv: Cap:AUTOLEVEL:1
Recv: Cap:Z_PROBE:1
Recv: Cap:LEVELING_DATA:1
Recv: Cap:SOFTWARE_POWER:0
Recv: Cap:TOGGLE_LIGHTS:0
Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
Recv: Cap:EMERGENCY_PARSER:0
Recv: ok
Send: M21
Recv: ok
Send: M155 S2
Recv: ok
Recv:  == T:13.70 /0.00 == B:12.97 /0.00 @:0 B@:0
Recv:  == T:13.49 /0.00 == B:13.23 /0.00 @:0 B@:0
Recv:  == T:13.28 /0.00 == B:13.49 /0.00 @:0 B@:0
Send: M140 S60
Recv: ok
Recv:  == T:13.44 /0.00 == B:13.18 /60.00 @:0 B@:0
Recv:  == T:13.70 /0.00 == B:13.28 /60.00 @:0 B@:0
Recv:  == T:13.02 /0.00 == B:13.54 /60.00 @:0 B@:127
Changing monitoring state from "Operational" to "Error: MINTEMP triggered, system stopped! Heater_ID: bed - Printer halted. kill() called!"
Send: M112
Send: N2 M112*35
Send: N3 M104 T0 S0*34
Send: N4 M140 S0*97
Connected to: Serial<id=0x6b3d4910, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Recv: start
Recv:
Recv:
Recv: echo:  M200 D0
Recv:
Recv: echo:  M200 D0
Recv: ok
Recv: ok
Recv: ok
Send: N1 M115*39
Recv: Cap:EEPROM:1
Recv: Cap:Z_PROBE:1
Recv: ok
Send: M21
Recv: ok
Send: M155 S2
Recv: ok
Send: M140 S60
Recv: ok
Send: M112
Send: N2 M112*35
Send: N4 M140 S0*97
The basement space my printer is kept in takes a lot of money to heat. With the colder weather, the basement has been around 13 celsius according to my printer. Heating the room to even 20 celsius is costly, but fixes the problem. Printer prints fantastic! Can I adjust something to set MINTEMP to trigger lower, or will that screw something up?
