My two Raspberry Pi 3 B+ will not connect via USB to my Creality Ender 3 Printer.
I swapped the Pi's and saw that on the first connection attemp the Raspy detected the printer very well. saw it on lsusb and also dmesg shows no error at all.
after rebooting the Pi (yes on both), i got this error msg (dmesg):
[ 170.459643] usb 1-1.2: new full-speed USB device number 9 using dwc_otg
[ 170.559593] usb 1-1.2: device descriptor read/64, error -32
[ 170.779633] usb 1-1.2: device descriptor read/64, error -32
[ 170.999577] usb 1-1.2: new full-speed USB device number 10 using dwc_otg
[ 171.099588] usb 1-1.2: device descriptor read/64, error -32
[ 171.319602] usb 1-1.2: device descriptor read/64, error -32
[ 171.439807] usb 1-1-port2: attempt power cycle
[ 172.099573] usb 1-1.2: new full-speed USB device number 11 using dwc_otg
[ 172.539639] usb 1-1.2: device not accepting address 11, error -32
[ 172.639550] usb 1-1.2: new full-speed USB device number 12 using dwc_otg
[ 173.079579] usb 1-1.2: device not accepting address 12, error -32
[ 173.079793] usb 1-1-port2: unable to enumerate USB device
lsusb is showing just this:
Bus 001 Device 008: ID 0424:7800 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
I further testet: Raspbian Jessie and Buster. I also tried the OctoPrint Image.
That octoprint isn't able to connect to my printer is obvious.
Can someone help my out with my issue? That would be very great!
Additional information about your setup (OctoPrint version, OctoPi version, printer, firmware, browser, operating system, ...)
