Printer gets to temp then I get this message and doesn't print.
Not sending M0 to printer, it's configured as a blocked command
Power cycle of the hardware and software, load different test.
ok it is working in safemode, so what do i have to do to get out of safemode??
the only plug in I added was the fix for temp "TT"
To leave safe mode, you just restart the Pi via the System menu.
If you have a M0 command in the Gcode, check your slicer.
You may share the beginning of a Gcode file that causes that issue.
I would like this to work the correct way. I understand how to get out of safemode.
how do i fix this???
You may share some more information of what you are using.
Most handy will be the logs.
