Erro: Device reports readiness to read but returned no data
Hello,I am a Octopi noob. I stopped 3D Printing for 9 months and when I came back I try to sett up everything again. Everything ran flawlessly with octopi in the past. Now when I try to print something with octopi I got the error message "SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?)" then the print Stops.
I have no clue about octopi when I was setting up octopi in the past everything worked.
I Updated octopi to the current firmware
Restarted my Wi-Fi
Tested it with the Raspberry Pi camera and without
Used different USB Ports
yes
no
octoprint-systeminfo-20230107011837.zip (131.2 KB)
Hello @Bertling31 !
It seems you have a very unreliable USB connection to the printer:
2023-01-06 01:06:45,908 - octoprint.util.comm - WARNING - Received line:
2023-01-06 01:06:45,909 - octoprint.util.comm - WARNING - | M‰‹ý•$‰£€•–"Ñ 2EdDDâЛff¶âÒ)z€@TZ–X¶ø0›†U	[‘„Ë!¦*@M%Ò5:¡ºe6,Ð-Z"À"Dý$"FÀ"BоÉÛPÉj %h¾€¢@"ÐF "Død$KSæ@ՙëa·¥BùKÐ" þDZ±k™ë—Àd›¯@LbB#:¦
•%"À$FB飕p6šm
•2ö-@«0ºƒK“…€·ïh3ցK`'Û`0°-\x00F¯V€\x00Î2\x00V€
˃2þ"DDD]D""%D¨ºðáUKdÐ^dDDMD"DZP¶B²Ù̀$K2$KS+Ó Ò2II•#‚¿"8 \x00K?"ø  ^˦UZR"DAEø¨>\x00‹#DIEø‘Dª>¢ºeËëKè’	•%É?Z"H˺ƒÖüKÐ
“Ëecho:Unknown command: ""
You may have a look on this:
BTW: What printer do you use?
also:
Pulling the plug from the Pi to reset dos not make it better, it gets even worse.
Hello,
Thank you for your help!
I am using an anycubic Mega X
I read this post with the Ender 3 but now I got some more questions, If understood it correct but I am not sure, The "Printer Cable" causes this sort of problems. But I don't know which cable he means with Printer cable, the Power Plug, The USB to RPi or something else.
What kind of plug do you mean with pulling the plug? Yeah i am noob I pull the plugs all the time to fix something lol
Usually this is the USB cable from the Pi to the printer.
I meant the power supply of the Pi.
The Pi is a small, but sophisticated computer and has to be shut down like a large one, else you can get in trouble with a corrupted file system on the SD card.
Oh thank you, from now on i will turn it off.
Do you have any suggestions how i can fix the problem with the USB Cable, i realy dont know what to do :frowning:
Recommended is a cable as short as possible, with ferrite beads and thick wires.
Such like this:
Thank you, i will test it and tell you in a few days
