I get the error massage and after doing the line i get this bag
pi@octopi:~ sudo service octoprint restart
pi@octopi:~ ps -ef | grep -i octoprint | grep -i python
pi 929 1 14 18:00 ? 00:00:18 /home/pi/oprint/bin/python2 /home/pi/oprint/bin/octoprint serve --host=127.0.0.1 --port=5000
Who can help my i have than all the update`s and grades but it will not help.
Moved this thread to the get help section, please fill in the template below and provide the logs etc. so we can help you better:
Complete Logs
OK, the logs are the most important. Something to do with the automatic linking of the words logs etc, but we will work with what we have.
The initial log file you have provided - it says that it is running OctoPrint 1.3.11 (edit the newer log shows 1.4.0), which is more than a year out of date. Was it after an update that this problem started?
It will take a few minutes, then you can run `sudo service octoprint restart and see what happens. If running in safe mode solved the problem, then this means there is a faulty plugin.
