I try to install OctoPrint on my laptop with Ubuntu 20.04 sticking to this guide:
Right after starting OctoPrint with octoprint serve, it ends immediately with an error message
Informed my about that error message, but even don't know what address is already in use...
Did not get that far
See above
Either not, but this:
(venv) pi@Leppy3D:~/OctoPrint$ octoprint serve
2022-09-12 21:30:32,319 - octoprint.startup - INFO - ******************************************************************************
2022-09-12 21:30:32,320 - octoprint.startup - INFO - Starting OctoPrint 1.8.2
2022-09-12 21:30:32,320 - octoprint.startup - INFO - ******************************************************************************
2022-09-12 21:30:32,323 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2022-09-12 21:30:32,323 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 1.1.1.1:53 is working
2022-09-12 21:30:32,323 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2022-09-12 21:30:32,325 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/OctoPrint/venv/lib/python3.8/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2022-09-12 21:30:32,657 - octoprint.plugin.core - INFO - Plugin Pi Support Plugin (2022.6.13) did not pass check, not loading.
2022-09-12 21:30:32,681 - octoprint.plugin.core - INFO - Found 17 plugin(s) providing 17 mixin implementations, 34 hook handlers
2022-09-12 21:30:32,692 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2022-09-12 21:30:32,696 - octoprint.cli.server - ERROR - Uncaught exception
File "/home/pi/OctoPrint/venv/bin/octoprint", line 8, in <module>
sys.exit(main())
File "/home/pi/OctoPrint/venv/lib/python3.8/site-packages/octoprint/__init__.py", line 936, in main
octo(args=args, prog_name="octoprint", auto_envvar_prefix="OCTOPRINT")
File "/home/pi/OctoPrint/venv/lib/python3.8/site-packages/click/core.py", line 1130, in __call__
return self.main(*args, **kwargs)
File "/home/pi/OctoPrint/venv/lib/python3.8/site-packages/click/core.py", line 1055, in main
rv = self.invoke(ctx)
File "/home/pi/OctoPrint/venv/lib/python3.8/site-packages/click/core.py", line 1657, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/home/pi/OctoPrint/venv/lib/python3.8/site-packages/click/core.py", line 1404, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/home/pi/OctoPrint/venv/lib/python3.8/site-packages/click/core.py", line 760, in invoke
return __callback(*args, **kwargs)
File "/home/pi/OctoPrint/venv/lib/python3.8/site-packages/click/decorators.py", line 26, in new_func
return f(get_current_context(), *args, **kwargs)
File "/home/pi/OctoPrint/venv/lib/python3.8/site-packages/octoprint/cli/server.py", line 317, in serve_command
run_server(
File "/home/pi/OctoPrint/venv/lib/python3.8/site-packages/octoprint/cli/server.py", line 163, in run_server
octoprint_server.run()
File "/home/pi/OctoPrint/venv/lib/python3.8/site-packages/octoprint/server/__init__.py", line 369, in run
self._start_intermediary_server()
File "/home/pi/OctoPrint/venv/lib/python3.8/site-packages/octoprint/server/__init__.py", line 2500, in _start_intermediary_server
self._intermediary_server.server_bind()
File "/usr/lib/python3.8/http/server.py", line 138, in server_bind
socketserver.TCPServer.server_bind(self)
File "/usr/lib/python3.8/socketserver.py", line 466, in server_bind
self.socket.bind(self.server_address)
OSError: [Errno 98] Address already in use
