Trying to upgrade OctoPi 0.17.0 to Python 3 per the scripts listed here: https://github.com/cp2004/Octoprint-Upgrade-To-Py3#using-this-script
Getting the following fetch error:
Checking package list for python3-dev
Installing python3-dev...
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/python3. 7/libpython3.7-dev_3.7.3-2_armhf.deb 404 Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/python3. 7/python3.7-dev_3.7.3-2_armhf.deb 404 Not Found [IP: 93.93.128.193 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-mis sing?
ERROR: failed to install python3-dev
Tried apt-get update, received the following:
Reading package lists... Done
E: Could not open lock file /var/lib/apt/lists/lock - open (13: Permission denied)
E: Unable to lock directory /var/lib/apt/lists/
W: Problem unlinking the file /var/cache/apt/pkgcache.bin - RemoveCaches (13: Permission denied)
W: Problem unlinking the file /var/cache/apt/srcpkgcache.bin - RemoveCaches (13: Permission denied)
octoprint-systeminfo-20211011200430.zip (38.3 KB)
Systeminfo Bundle attached.
OctoPrint 1.7.0
OctoPi 0.17.0
Printer Ender 3
