Fresh install, have psu control, psu control tp-link, filament sensor simplified
changed usb cables, installed ferrite Bead on cable, tried two different usb ports
yes, fails first connect
no
octoprint-systeminfo-20220119214819.zip (46.2 KB)
terminal.log (1.7 KB)
included part of terminal window. Using chrome on windows 11, Pi imager loaded the latest stable. Running on a Pi4. Printer running Jyers - bugfix-JyersUI 2.0.1
Don't understand, I was running fine till I moved the pi to my desk to change the camera ribbon. The micro sd got dislodged and burned up, so doing new install. First time thru, had problems so ordered a tp-link smart plug to use instead of my relay off of a gpio pin and doing a fresh install with pi imager, the first time it tries to connect it gets a mismatch error, if I try to connect again, it does connect. Frustrating because when loading the original, once working correctly, it worked fine for almost a year.
Edit: If I remove my 5v blocker ( USB Power Blocker – Power BLough-R) which leaves the screen up, it connects ok. I think this is because the 5v keeps the card up? Is there a serial setting that will slow it down enough to not error?
