Ender 3 Pro with 4.2.7 board Error:Bed Heating failed, system stopped! bed will not got over 50 degrees
no
Attached
Ender 3 Pro I had for 4 years, updated to 4.2.7 board last year.
running current firmware from marlin.crc.id.au : Ender3-v4.2.7-Stock-20240206.bin OctoPrint : 1.9.3
Everything worked great on older firmware, I have just updated to the latest Marlin (tried several days of updates.
Hotend goes right up to temp, but the Bed once it hits 50 stalls for a few minutes and then trips error
Thanks, I tested all your suggestions, with the same result every time.
I reinstalled the latest firmware from the Creality site and it goes up to 60 with no problem.
there is the heater that heats. the temp sensor that senses said heat.
The heater is bad and/or the temperature sensor is bad. After so many readings nothing changes it will error.
replace both, one at a time, and test.
Let us know how it goes....
