setting up a development platform on Windows 10 for plugin developement. Using:
Windows 10
Python 3.8
Octoprint 1.4.0rc3
Octoprint loads fine. I can access the web interface via localhoast:5000. Builtin plugins load without issue. If I try to add any (get more) plugins I get an immediate error that:
Installing plugin "OctoPrint-SideBarTempGraph" from https://github.com/jneilliii/OctoPrint-SideBarTempGraph/archive/master.zip...
d:\github\octoprint\venv3b\scripts\python.exe -m pip --disable-pip-version-check install https://github.com/jneilliii/OctoPrint-SideBarTempGraph/archive/master.zip --no-cache-dir
Error!
> Could not parse output from pip, see plugin_pluginmanager_console.log for generated output
I have updated the origional build, I have tried reinstalling in a fresh environment, I have searched for answers
the pip path may be suspect, but im not fluent enough to know if this is the problem or if it is, how to solve it:
octoprint (3).log (70.1 KB) plugin_pluginmanager_console (6).log (2.2 KB)
This is the last bit from the console that shows the errors:
2019-12-30 16:48:36,673 - octoprint.plugins.pluginmanager - INFO - Installing plugin from https://github.com/jneilliii/OctoPrint-SideBarTempGraph/archive/master.zip
2019-12-30 16:48:36,736 - octoprint.plugin.core - INFO - Plugin Pi Support Plugin did not pass check, not loading.
2019-12-30 16:48:36,810 - octoprint.util.pip - ERROR - Error while trying to run command d:\github\octoprint\venv3b\scripts\python.exe -m pip --disable-pip-version-check install https://github.com/jneilliii/OctoPrint-SideBarTempGraph/archive/master.zip --no-cache-dir
2019-12-30 16:48:36,816 - octoprint.plugins.pluginmanager - ERROR - Installing the plugin from https://github.com/jneilliii/OctoPrint-SideBarTempGraph/archive/master.zip failed, could not parse output from pip. See plugin_pluginmanager_console.log for generated output
2019-12-30 16:58:54,615 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-12-30 16:58:58,963 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 1803}
self.run()
File "d:\github\octoprint\venv3b\lib\site-packages\sentry_sdk\integrations\threading.py", line 69, in run
self.run()
reraise(*_capture_exception())
File "d:\github\octoprint\venv3b\lib\site-packages\sentry_sdk\_compat.py", line 57, in reraise
raise value
File "d:\github\octoprint\venv3b\lib\site-packages\sentry_sdk\integrations\threading.py", line 67, in run
raise value
return old_run_func(self, *a, **kw)
File "c:\users\joshu\appdata\local\programs\python\python38-32\Lib\threading.py", line 870, in run
self._target(*self._args, **self._kwargs)
File "d:\github\octoprint\venv3b\lib\site-packages\sarge\__init__.py", line 1187, in run_node
result = getattr(self, method)(node, input, async_)
File "d:\github\octoprint\venv3b\lib\site-packages\sarge\__init__.py", line 1333, in run_command_node
node.cmd.run(input=input, async_=async_)
File "d:\github\octoprint\venv3b\lib\site-packages\sarge\__init__.py", line 655, in run
self.process = p = Popen(self.args, **self.kwargs)
File "d:\github\octoprint\venv3b\lib\site-packages\sentry_sdk\integrations\stdlib.py", line 205, in sentry_patched_popen_init
rv = old_popen_init(self, *a, **kw) # type: ignore
File "c:\users\joshu\appdata\local\programs\python\python38-32\Lib\subprocess.py", line 854, in __init__
self._execute_child(args, executable, preexec_fn, close_fds,
File "c:\users\joshu\appdata\local\programs\python\python38-32\Lib\subprocess.py", line 1307, in _execute_child
hp, ht, pid, tid = _winapi.CreateProcess(executable, args,
TypeError: environment can only contain strings
Thanks for any help.
