I'm getting an error trying to install the plugin via the command line.
The command line, the URL, and the search bar (it won't click on the install button)
Complete Logs
Collecting https://github.com/bradcfisher/OctoPrint-ExcludeRegionPlugin/archive/master.zip
Using cached https://github.com/bradcfisher/OctoPrint-ExcludeRegionPlugin/archive/master.zip
ERROR: Command errored out with exit status -1:
command: 'c:\python27\python.exe' -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'c:\users\mb\appdata\local\temp\pip-req-build-j1zz9r\setup.py'"'"'; file='"'"'c:\users\mb\appdata\local\temp\pip-req-build-j1zz9r\setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(file);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, file, '"'"'exec'"'"'))' egg_info --egg-base 'c:\users\mb\appdata\local\temp\pip-pip-egg-info-c4b_r4'
cwd: c:\users\mb\appdata\local\temp\pip-req-build-j1zz9r
Complete output (1 lines):
Could not import OctoPrint's setuptools, are you sure you are running that under the same python installation that OctoPrint is installed under?
ERROR: Command errored out with exit status -1: python setup.py egg_info Check the logs for full command output.
Octoprint v3, running on Win10 in google chrome.
I'm also running two printers in two different tabs. I made a copy of octoprint and named it octoprint2 and assigned it the port 5001. But the application is named octoprint in both folders.
