I'm using the fintech guide to install a 3.5 touchscreen. When booting, the text goes to the touch screen so those drivers worked. When I run sudo ~/TouchUI-autostart/helpers/install, i get this:
[sudo] password for pi:
Install helper v0.0.4
Boot to command line:
- success
Running apt-get update (this will take a while)
Do NOT switch off the Pi or close this console until done!
- failed
pi@raspberrypi:~ $
used a clean install of Octoprint with only the touch plugin enabled.
no
I have the system bundle, but I can't see how to attach it to this.
what happens when you run sudo apt-get update ?
It looks like I'm getting an error.
pi@raspberrypi:~ $ sudo apt-get update
Get:1 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Get:3 http://archive.raspberrypi.org/debian buster/main armhf Packages [378 kB]
Reading package lists... Done
E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
try to run
sudo apt-get update --allow-releaseinfo-change
and then again
sudo apt-get update
and check if the error is gone
Thanks, that worked! I tried those so many times, I'm blaming it on my extreme dyslexia. I'm truly mystified.
No worries
Now the touchui script should work again
The fintech guide has an error. It's missing the second dash "ie -allow" instead of "--allow"
I have posted in the guide.
Thanks again!
I was able to load the GUI, but calibration reversed x,y axis.
once I created the following file, the GUI fails to load, it boots to the Linux login prompt
From the same guide, I created the config file
You can now modify your 99-calibration.conf file
sudo nano /usr/share/X11/xorg.conf.d/99-calibration.conf
Copy and past below
Section “InputClass”
Identifier “calibration”
MatchProduct “ADS7846 Touchscreen”
Driver “evdev”
Option “Calibration” “3936 227 268 3880”
Option “InvertY” “true”
Option “InvertX” “false”
EndSection
