**Slicer
Cura 4.9.0
Keep getting the following error message everytime i try to print someting
Attention
Layer indicator not found in file: 'Wyze_Cam_Tripod_Mount_V6_Tests.gcode'
Check layer pattern in DisplayLayerProgress-Settings and reupload the file!
I am new to 3d Printing, i may have changed a paramter somewhere, not sure where. Might be somethig to do with when i was trying to get octolapse working
Logs (octoprint.log, serial.log or output on terminal tab, ... no logs, no support)
octoprint-logs.zip (137.8 KB)
Example GCODE file
Wyze Cam Tripod Mount V6 Tests.zip (1.3 MB)
Additional information about your setup (OctoPrint version, OctoPi version, printer, firmware...)
I am using the latest version of OctoPi and Cura with an Ender3v2
Appreciate if someone can help please.
