When i wanted to start a print a get "Error: Printer halted. kill() called!" response and printer disconnects and never connect until i manually restart it.
Before clicking the "Load and Print" icon everthing (axis control, bed temp control, terminal commands etc) works without any problem.
Printer can print the gcode i wanted with usb without any problem. Same gcode does not work with octoprint.
Yes, same problem exists on safe mode.
Complete Logs
serial (1).log (11.3 KB) octoprint (3).log (122.8 KB)
OctoPrint 1.5.1, OctoPi 0.17.0, SKR 1.4 Turbo
