Hello, I need help because when I want to render a timelapse the server restarts and it can't render any timelapse, I tried running the server in safe mode but it didn't work, does anyone have an idea of a solution?
Hi ![]()
Your problem could have several causes - for example a bad psu or a corrupted sd card.
Did you have the problem from the beginning or after a while?
Please upload a systeminfo bundle so we can check the logs.
