Octoprint version Version 1.5.2
octopi Version 0.18.0, running on Raspberry Pi 4 Model B Rev 1.1
ubuntu mate 18.04.5 lts 64
printer 3d longer lk4 pro
I didn't modify firmware of printer
I see on printer lcd error 0 abnormal E temperature
Octoprint didn't start any temperature.
I had also the log file, but I can't upload here.
Thank you
Without the log file, all we can do is have sympathy.
You may zip it and share it here as file.
Thank you within tomorrow i Will share log file via link shared.
You have a thermal runaway issue:
2021-04-06 20:16:31,083 - octoprint.util.comm - WARNING - Received an error from the printer's firmware: Heating failed, system stopped! Heater_ID: 0 - Printer halted. kill() called!
| Last lines in terminal:
| Recv: T:23.09 /180.00 B:22.97 /0.00 @:127 B@:0
| Recv: T:23.05 /180.00 B:23.48 /0.00 @:127 B@:0
| Recv: T:23.01 /180.00 B:22.70 /0.00 @:127 B@:0
| Recv: T:23.12 /180.00 B:23.28 /0.00 @:127 B@:0
| Recv: T:23.55 /180.00 B:22.89 /0.00 @:127 B@:0
| Recv: T:23.12 /180.00 B:22.85 /0.00 @:127 B@:0
| Recv: T:22.97 /180.00 B:22.97 /0.00 @:127 B@:0
| Recv: T:22.77 /180.00 B:23.24 /0.00 @:127 B@:0
| Recv: T:23.09 /180.00 B:22.89 /0.00 @:127 B@:0
| Recv: T:22.97 /180.00 B:23.20 /0.00 @:127 B@:0
| Recv: T:22.85 /180.00 B:23.59 /0.00 @:127 B@:0
| Recv: T:23.09 /180.00 B:22.85 /0.00 @:127 B@:0
| Recv: T:23.01 /180.00 B:22.85 /0.00 @:127 B@:0
| Recv: T:23.32 /180.00 B:23.12 /0.00 @:127 B@:0
| Recv: T:23.20 /180.00 B:22.77 /0.00 @:127 B@:0
| Recv: T:23.01 /180.00 B:23.12 /0.00 @:127 B@:0
| Recv: T:23.12 /180.00 B:23.12 /0.00 @:127 B@:0
| Recv: T:23.28 /180.00 B:23.12 /0.00 @:127 B@:0
| Recv: Error:Heating failed, system stopped! Heater_ID: 0
| Recv: Error:Printer halted. kill() called!
The hotend is set to 180Β°C but it's not heating up.
Check:
- Is the printer powered properly?
- Is the printer power supply working?
- Can you move the printhead from the printers menu (this is to check the printer power supply)?
- Is the thermistor properly attached to the hotend?
- If there is a fuse for the high power rail on the printer board: is it ok?
BTW: You can attach files to your posts
ok sorry it is I guess very simple, I didn't know if i had to power on the printer 3d because the panel lcd opened without button of powered 3d printer.
Now I understood that i have to power on printer 3d.
Sorry for the my idiot mystake, within tomorrow I try again, I had the printer in a warehouse
