I was trying to install a new pluggin for full screen webcam in octoprint, and my Pi 4B kept showing up with "Error!
System is currently throttled, refusing to install anything due to possible stability isssues"
I have used the power supply buck converter from the printer to the pi, with 2 different usb cables, and an alternate external power brick. The lightning bold doesn't show up, so I don't think it's under powered? I even tried the tape mod for the printer usb cable. I have also restarted the printer and the pi connected, and disconnected several times
Yes
Safe mode won't let me install the new plugin I was trying to set up...
Complete Logs
octoprint.log (219.5 KB)
As far as I know, I am running the newest versions of everything, as I set everything up less than a week ago (and it was working fine for a few days) the Pi model is the 4B with a 16gb sandisk ultra micro SD card, plugged into my Prusa i3 Mk3s+ with a buck converter stepping the 24v down to 5 (previously attached to a under powered usb hub)
