Error upgrading
I have been using Octopri PI to run my octoprint server for probably 5 years not. Works great still but for last year or so I have not been able to upgrade octoprint. I am versed enough to get things working but not bug fixes. So I have put this off. This same thing happens for 4 of the software updates, OctoPrint, File Check Plugin, Firmware Check Plugin and PI Support Plugin. Screenshots of versions attached.
When I run the update software below is part of the error. But all logs are attached that error indicated to look at.
AttributeError: type object 'Callable' has no attribute '_abc_registry'
ERROR: Command errored out with exit status 1: /home/pi/oprint/bin/python3 /home/pi/oprint/lib/python3.7/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-69ptji4h/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i Simple index --extra-index-url piwheels - Simple index -- 'setuptools>=40.8.0' wheel Check the logs for full command output.
Installing build dependencies: finished with status 'error'
octoprint (3).log (599.5 KB)
plugin_softwareupdate_console (2).log (5.5 KB)
Disabled unused plugins, deleted them to see if that was an issue. Did some searches but really don't know how to solve this.
yes
octoprint-systeminfo-20251111174400.zip (1.1 MB)
Build 2022.01.20.112925 with "webcamd", based on OctoPi 0.18.0, running on Raspberry Pi 4 Model B Rev 1.4
I am in the same boat you're in. I was just planning on creating a whole new octoprint Install.
