am running OctoPi on a Raspberry Pi 3 . I've been running it for a couple of months now. When I got the notification about 1.4.0, I clicked "Update now" but this time I got an error.
Complete Logs
2020-08-19 05:43:00,114 - octoprint.plugins.softwareupdate - INFO - Starting update of octoprint to 1.4.2...
2020-08-19 05:43:00,147 - octoprint.util.pip - ERROR - Error while trying to run command /home/pi/oprint/bin/python2 -m pip --disable-pip-version-check install https://github.com/foosel/OctoPrint/archive/1.4.2.zip --no-cache-dir
2020-08-19 05:43:00,149 - octoprint.plugins.softwareupdate - ERROR - Update of octoprint can not be performed, please also check plugin_softwareupdate_console.log for possible causes of this
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/softwareupdate/init.py", line 987, in _perform_update
update_result = updater.perform_update(target, populated_check, target_version, log_cb=self._log, online=online)
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/softwareupdate/updaters/pip.py", line 116, in perform_update
raise exceptions.UpdateError("Error while executing pip install", (stdout, stderr))
UpdateError
2020-08-19 05:43:00,581 - octoprint.plugins.tracking - INFO - Sent tracking event update_failed, payload: {'to_version': u'1.4.2', 'from_version': u'1.3.12', 'target': 'octoprint'}
2020-08-19 05:48:44,228 - octoprint.server.heartbeat - INFO - Server heartbeat <3
I tried to update the TheSpaghettiDetective pluggin and I get same error:
2020-08-19 05:39:12,956 - octoprint.plugins.softwareupdate - INFO - Starting update of TheSpaghettiDetective to 1.3.3...
2020-08-19 05:39:12,996 - octoprint.util.pip - ERROR - Error while trying to run command /home/pi/oprint/bin/python2 -m pip --disable-pip-version-check install https://github.com/TheSpaghettiDetective/OctoPrint-TheSpaghettiDetective/archive/1.3.3.zip --no-cache-dir
2020-08-19 05:39:12,996 - octoprint.plugins.softwareupdate - ERROR - Update of TheSpaghettiDetective can not be performed, please also check plugin_softwareupdate_console.log for possible causes of this
UpdateError/small>
Thanks,
