Error while reading repository data
When trying to install Octoprint plugins, I get an error message that there was an error while reading the repository data:
2023-05-22 09:14:58,617 - octoprint.plugins.pluginmanager - ERROR - Error while reading repository data: Expecting property name enclosed in double quotes: line 13592 column 8 (char 481228)
Those are the "offending" Lines
13591 "id": "karmen",
13592 "published": "2022-08-15 00:00:00 +0000",
13593 "title": "Karmen Connector",
Restart the server multiple times
No, because it looks like a corrupt JSON may be the culprit
N/A
octoprint-systeminfo-20230522091506.zip (6.0 KB)
Octoprint 1.8.7 on Armbian 22.11.0-trunk Bullseye with bleeding edge Linux 6.1.11-sunxi running on a Banana Pi M2 Ultra
You can try to install via the url:
[type or paste code here](https://github.com/fragaria/karmen-octoprint-plugin/archive/refs/heads/main.zip)
within the Plugin Manager
Thank you for your reply.
That would not solve my problem sadly, because the issue here is that I do not see any plugins because the loading from the repository fails.
I took a screenshot to show what I mean, please ignore the message of an ongoing print, the error regarding the repository also appears when not printing.
Just to be sure I tried to install the plugin you pasted and install it manually, but this also fails, although the error here seems to be related to another issue I found while searching for an answer to mine, being that the building of the wheel fails.
I will try to resolve that issue as soon as my print finishes, maybe it fixes my repository problem as well.
Hi Philipp,
this is definitely a very abnormal error.
2023-05-22 09:14:58,550 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from https://plugins.octoprint.org/plugins.json
2023-05-22 09:14:58,617 - octoprint.plugins.pluginmanager - ERROR - Error while reading repository data: Expecting property name enclosed in double quotes: line 13592 column 8 (char 481228) Traceback (most recent call last):
Lines 288,289 in the octoprint log you provided, complains about missing quotes read from a file from a plugins web page and viewing the web page I see quotes in exactly the spot where it complains about the missing quotes.
      "id": "karmen",
Earlier in the log on line 49 it states however that it can not check for updates, so is the pi able to access the web or not?
2023-05-21 21:07:53,570 - octoprint.plugins.softwareupdate - ERROR - Could not check octoprint for updates Traceback (most recent call last):
If it has web access, and it's capable of reading the plugins file, then the file gets corrupted or it's a cached file that kept on being loaded. It might also be a similar issue of a file being read and getting corrupted.
In my experience these types of issues are normally related to hardware problems.
  • Is the pi connected over wifi or ethernet cable?
  • Are you getting low power messages from octoprint?
  • You might have a failing SD card, scan and check the SD card, I had several of them failing on my Pi's.
I hope this helps some.
Thank you as well for your input.
To your points:
  • Yes, the Pi is able to connect to the internet perfectly fine (ping google.com average 24ms)
  • No, I do not receive any low power warnings, and I have specifically bought the beefiest wall plug I could get with micro USB (3 Amps) in order to rule out any of those issues
  • The SD card worked perfectly fine while being in my Pihole, so that seems unlikely, but I will try another SD card nonetheless (and reinstall Octoprint in the process, which might resolve this issue anyway, I just did not do that yet because I want to finish a printing project and don't want to switch over to SD card directly at the printer midway).
I agree that this is an abnormal error (although I tend to attract those :expressionless: ), moreso because there are hundreds of quotation marks before the offending line, so I would also rule out any charset errors here.
I have seen that it is possible to manually provide the location of the plugin repository, I will try that as soon as I get home from work, if that does not help I will reinstall, and if THAT does not help either I will switch my Pi 3B+ Pihole with the Banana Pi and simply flash Octopi. I wanted to keep the "authentic" Pi in reserve for my Voron project, but seeing as this issue might be highly specific and not easily solved I might just give in and try to source another Pi somehow. It should get better in a few weeks I understand.
Best regards!
