Raspberry Pi Camera v3
The webcam URL at webcam/?action=stream does not load. In the control tab in octoprint, its stuck on "webcam stream loading"
I see the following error in webcamd.log, but cannot seem to find cause. The camera is on /dev/video0
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 1536x864 -f 10
raspi options: -fps 10
http options: -w ./www-octopi -n
Explicitly set USB device:
Found video devices:
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video31
raspi
config file='/boot/octopi.txt':USB device was not set in options, starting MJPG-streamer with the first found video device: /dev/video0
<13>Sep 30 05:22:46 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n -i input_uvc.so -r 1536x864 -f 10 -d /dev/video0
MJPG Streamer Version.: 2.0
i: Desired Resolution: 1536 x 864
i: Frames Per Second.: 10
i: Format............: JPEG
o: HTTP Listen Address..: (null)
libv4l2: error turning on stream: Invalid argument
Unable to start capture: Invalid argument
i: Can't enable video in first time
i: cleaning up resources allocated by input thread
Done bringing up all configured video devices
I have tried enabling/disabling legacy camera support
I have verified the camera works outside of octoprint using libcamera
I have tried unsuccessfully to use the mjpg_streamer command to start the webserver
I tried setting the options in /boot/octopi.txt as per setup instructions:
camera_http_webroot="./www-octopi"
camera_http_options="-n"
camera_usb_options="-r 1536x864 -f 10"
Yes
octoprint-systeminfo-20240930053358.zip (43.6 KB)
Running on a raspberry pi 3 with Raspbian 11
