Hi everyone,
I'm running Octopi with Octoprint on my RPi 4. I just changed my SD card with a new system installation. At first, all working fine, OS still boot up and seems working but I've seen some errors in dmesg (see last 3 lines in red on Putty). What are they meen ? What can I do?
Don't know what can I do...
octoprint-systeminfo-20211106175640.zip (625.1 KB)
pi@octopi:~ $ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.63-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1459 SMP Wed Oct 6 16 :41:57 BST 2021
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
[ 0.000000] random: fast init done
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000002ac00000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x0000000030000000-0x000000007fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x000000007fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] On node 0 totalpages: 504832
[ 0.000000] DMA zone: 1728 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 196608 pages, LIFO batch:63
[ 0.000000] HighMem zone: 308224 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u81920
[ 0.000000] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 503104
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=800 bcm2708_fb.fbheight=480 bcm2708_ fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:2A:24:77 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=0ae22527-02 rootfstype=ext4 eleva tor=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Kernel parameter elevator= does not have any effect anymore.
Please use sysfs to set IO scheduler for individual devices.
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x0000000025a00000-0x0000000029a00000] (64MB)
[ 0.000000] Memory: 1850028K/2019328K available (10240K kernel code, 1364K rwdata, 3192K rodata, 2048K init, 891K bss, 103764K reserved, 65536K cma-reserved, 1232896K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 34315 entries in 68 pages
[ 0.000000] ftrace: allocated 68 pages with 2 groups
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=1
[ 0.000007] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000026] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000083] bcm2835: system timer (irq = 25)
[ 0.000724] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000742] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000761] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000775] Switching to timer-based delay loop, resolution 18ns
[ 0.001024] Console: colour dummy device 80x30
[ 0.001091] printk: console [tty1] enabled
[ 0.001147] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ 0.001179] pid_max: default: 32768 minimum: 301
[ 0.001343] LSM: Security Framework initializing
[ 0.001525] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001550] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.003002] cgroup: Disabling memory control group subsystem
[ 0.003230] CPU: Testing write buffer coherency: ok
[ 0.003673] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004867] Setting up static identity map for 0x200000 - 0x20003c
[ 0.005063] rcu: Hierarchical SRCU implementation.
[ 0.005968] smp: Bringing up secondary CPUs ...
[ 0.007126] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.008448] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.009701] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.009859] smp: Brought up 1 node, 4 CPUs
[ 0.009880] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.009895] CPU: All CPU(s) started in HYP mode.
[ 0.009909] CPU: Virtualization extensions available.
[ 0.010749] devtmpfs: initialized
[ 0.025052] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.025282] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.025310] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.027163] pinctrl core: initialized pinctrl subsystem
[ 0.028186] NET: Registered protocol family 16
[ 0.031996] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.032754] audit: initializing netlink subsys (disabled)
[ 0.033012] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
[ 0.033581] thermal_sys: Registered thermal governor 'step_wise'
[ 0.034385] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.034402] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.034796] Serial: AMBA PL011 UART driver
[ 0.068359] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.080807] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-09-30T19:21:03, variant start
[ 0.090820] raspberrypi-firmware soc:firmware: Firmware hash is 51215b4f6e3966401ecd99652a35cf1c25069113
[ 0.132577] Kprobes globally optimized
[ 0.137597] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.141781] vgaarb: loaded
[ 0.142220] SCSI subsystem initialized
[ 0.142443] usbcore: registered new interface driver usbfs
[ 0.142515] usbcore: registered new interface driver hub
[ 0.142588] usbcore: registered new device driver usb
[ 0.142938] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.144893] clocksource: Switched to clocksource arch_sys_counter
[ 1.102822] VFS: Disk quotas dquot_6.6.0
[ 1.102916] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.103076] FS-Cache: Loaded
[ 1.103272] CacheFiles: Loaded
[ 1.113365] NET: Registered protocol family 2
[ 1.113585] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 1.115338] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.115381] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.115447] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.115518] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.115670] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.115706] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.115989] NET: Registered protocol family 1
[ 1.116692] RPC: Registered named UNIX socket transport module.
[ 1.116708] RPC: Registered udp transport module.
[ 1.116723] RPC: Registered tcp transport module.
[ 1.116737] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.116760] PCI: CLS 0 bytes, default 64
[ 1.119771] Initialise system trusted keyrings
[ 1.120001] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 1.128263] zbud: loaded
[ 1.130388] FS-Cache: Netfs 'nfs' registered for caching
[ 1.131158] NFS: Registering the id_resolver key type
[ 1.131206] Key type id_resolver registered
[ 1.131222] Key type id_legacy registered
[ 1.131363] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.131380] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.132422] Key type asymmetric registered
[ 1.132439] Asymmetric key parser 'x509' registered
[ 1.132630] bounce: pool size: 64 pages
[ 1.132672] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.132871] io scheduler mq-deadline registered
[ 1.132887] io scheduler kyber registered
[ 1.137202] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.137234] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.137313] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[ 1.137402] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x007fffffff -> 0x0400000000
[ 1.177024] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.177416] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.177437] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.177459] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.177547] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.177788] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.181216] PCI: bus0: Fast back to back transfers disabled
[ 1.181565] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.181693] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.182126] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 1.185575] PCI: bus1: Fast back to back transfers disabled
[ 1.185683] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.185708] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.185791] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.185817] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.186232] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 1.186442] pcieport 0000:00:00.0: PME: Signaling with IRQ 63
[ 1.187354] bcm2708_fb soc:fb: FB found 2 display(s)
[ 1.195902] Console: switching to colour frame buffer device 100x30
[ 1.198096] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 800x480
[ 1.201823] bcm2708_fb soc:fb: Registered framebuffer for display 1, size 640x480
[ 1.207065] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 1.207953] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default
[ 1.210397] iproc-rng200 fe104000.rng: hwrng registered
[ 1.210693] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.211573] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.223632] brd: module loaded
[ 1.235855] loop: module loaded
[ 1.237565] Loading iSCSI transport class v2.0-870.
[ 1.240777] libphy: Fixed MDIO Bus: probed
[ 1.242471] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.254938] libphy: bcmgenet MII bus: probed
[ 1.335082] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.336231] usbcore: registered new interface driver r8152
[ 1.336301] usbcore: registered new interface driver lan78xx
[ 1.336362] usbcore: registered new interface driver smsc95xx
[ 1.337957] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
[ 1.338129] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.338164] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.340861] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000060000000890
[ 1.342201] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 1.342220] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.342238] usb usb1: Product: xHCI Host Controller
[ 1.342254] usb usb1: Manufacturer: Linux 5.10.63-v7l+ xhci-hcd
[ 1.342270] usb usb1: SerialNumber: 0000:01:00.0
[ 1.342997] hub 1-0:1.0: USB hub found
[ 1.343096] hub 1-0:1.0: 1 port detected
[ 1.343763] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.343790] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.343815] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.344363] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 1.344382] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.344399] usb usb2: Product: xHCI Host Controller
[ 1.344415] usb usb2: Manufacturer: Linux 5.10.63-v7l+ xhci-hcd
[ 1.344431] usb usb2: SerialNumber: 0000:01:00.0
[ 1.345195] hub 2-0:1.0: USB hub found
[ 1.345287] hub 2-0:1.0: 4 ports detected
[ 1.346977] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.347291] dwc_otg: FIQ enabled
[ 1.347306] dwc_otg: NAK holdoff enabled
[ 1.347320] dwc_otg: FIQ split-transaction FSM enabled
[ 1.347338] Module dwc_common_port init
[ 1.347799] usbcore: registered new interface driver uas
[ 1.347909] usbcore: registered new interface driver usb-storage
[ 1.348102] mousedev: PS/2 mouse device common for all mice
[ 1.349739] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.353082] sdhci: Secure Digital Host Controller Interface driver
[ 1.353097] sdhci: Copyright(c) Pierre Ossman
[ 1.353798] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 1.354406] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.358500] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.358848] hid: raw HID events driver (C) Jiri Kosina
[ 1.359034] usbcore: registered new interface driver usbhid
[ 1.359049] usbhid: USB HID core driver
[ 1.364423] Initializing XFRM netlink socket
[ 1.364465] NET: Registered protocol family 17
[ 1.364571] Key type dns_resolver registered
[ 1.365268] Registering SWP/SWPB emulation handler
[ 1.365451] registered taskstats version 1
[ 1.365478] Loading compiled-in X.509 certificates
[ 1.366295] Key type ._fscrypt registered
[ 1.366312] Key type .fscrypt registered
[ 1.366327] Key type fscrypt-provisioning registered
[ 1.377964] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.378278] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.378355] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
[ 1.385769] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default
[ 1.386557] printk: console [ttyS0] disabled
[ 1.386684] fe215040.serial: ttyS0 at MMIO 0xfe215040 (irq = 38, base_baud = 62500000) is a 16550
[ 1.386883] printk: console [ttyS0] enabled
[ 1.387897] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.388946] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.388964] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.419242] of_cfs_init
[ 1.419513] of_cfs_init: OK
[ 1.442932] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.444618] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.446474] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.449524] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.451229] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.457659] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.458283] Waiting for root device PARTUUID=0ae22527-02...
[ 1.532582] mmc1: new high speed SDIO card at address 0001
[ 1.564992] mmc0: new ultra high speed DDR50 SDHC card at address 1234
[ 1.565837] mmcblk0: mmc0:1234 SA32G 28.9 GiB
[ 1.567782] mmcblk0: p1 p2
[ 1.584994] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.585065] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.590165] devtmpfs: mounted
[ 1.599981] Freeing unused kernel memory: 2048K
[ 1.624952] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.645239] Run /sbin/init as init process
[ 1.645254] with arguments:
[ 1.645268] /sbin/init
[ 1.645283] splash
[ 1.645296] with environment:
[ 1.645311] HOME=/
[ 1.645325] TERM=linux
[ 1.807590] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.807612] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.807630] usb 1-1: Product: USB2.0 Hub
[ 1.809561] hub 1-1:1.0: USB hub found
[ 1.809899] hub 1-1:1.0: 4 ports detected
[ 2.049995] systemd[1]: System time before build time, advancing clock.
[ 2.134972] usb 1-1.2: new full-speed USB device number 3 using xhci_hcd
[ 2.143151] NET: Registered protocol family 10
[ 2.144547] Segment Routing with IPv6
[ 2.213454] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.214441] systemd[1]: Detected architecture arm.
[ 2.277202] usb 1-1.2: config 1 interface 0 altsetting 0 has 2 endpoint descriptors, different from the interface descriptor's value: 1
[ 2.280948] usb 1-1.2: New USB device found, idVendor=0483, idProduct=5750, bcdDevice= 2.00
[ 2.280967] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.280984] usb 1-1.2: Product: MPI5001
[ 2.281002] usb 1-1.2: Manufacturer: QDtech
[ 2.281019] usb 1-1.2: SerialNumber: MPI5001ΰ΄
ΠΖ‘Ζ
βΚ‘δ
[ 2.286614] systemd[1]: Set hostname to <octopi>.
[ 2.303818] input: QDtech MPI5001 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:0483:5750.0001/input/input0
[ 2.304345] hid-generic 0003:0483:5750.0001: input,hidraw0: USB HID v1.01 Device [QDtech MPI5001] on usb-0000:01:00.0-1.2/input0
[ 2.404966] usb 1-1.4: new high-speed USB device number 4 using xhci_hcd
[ 2.767342] usb 1-1.4: New USB device found, idVendor=046d, idProduct=0825, bcdDevice= 0.12
[ 2.767364] usb 1-1.4: New USB device strings: Mfr=0, Product=0, SerialNumber=2
[ 2.767383] usb 1-1.4: SerialNumber: 59448820
[ 3.078502] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.095075] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.096138] systemd[1]: Listening on Journal Socket.
[ 3.096456] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.097063] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.097723] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 3.105514] systemd[1]: Mounting RPC Pipe File System...
[ 3.106575] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 3.108040] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.109267] systemd[1]: Listening on udev Control Socket.
[ 3.266773] i2c /dev entries driver
[ 3.720184] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.817682] systemd-journald[127]: Received request to flush runtime journal from PID 1
[ 4.418807] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 4.419438] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 4.419983] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 4.430098] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 4.494090] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.496381] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 4.496406] [vc_sm_connected_init]: start
[ 4.497230] [vc_sm_connected_init]: installed successfully
[ 4.499234] mc: Linux media interface: v0.10
[ 4.523234] videodev: Linux video capture interface: v2.00
[ 4.577306] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.590458] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 4.604826] bcm2835_audio bcm2835_audio: card created with 2 channels
[ 4.612401] bcm2835_audio bcm2835_audio: card created with 2 channels
[ 4.615676] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.617568] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.623570] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.628029] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.629086] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 4.629138] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 4.632247] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.633436] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 4.633480] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 4.643419] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 4.643478] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 4.665465] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 4.665915] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 4.666343] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 4.666656] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 4.666686] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 4.666711] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 4.666733] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 4.666755] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 4.667069] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 4.671128] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 4.671176] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 4.979887] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.076988] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 5.142595] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 5.166776] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.168469] usbcore: registered new interface driver brcmfmac
[ 5.269458] input: QDtech MPI5001 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:0483:5750.0001/input/input1
[ 5.270195] hid-multitouch 0003:0483:5750.0001: input,hidraw0: USB HID v1.01 Device [QDtech MPI5001] on usb-0000:01:00.0-1.2/input0
[ 5.438054] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.438175] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.447890] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan 4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
[ 6.762284] usb 1-1.4: set resolution quirk: cval->res = 384
[ 6.764210] usbcore: registered new interface driver snd-usb-audio
[ 6.764568] uvcvideo: Found UVC 1.00 device <unnamed> (046d:0825)
[ 6.811193] input: UVC Camera (046d:0825) as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input2
[ 6.811636] usbcore: registered new interface driver uvcvideo
[ 6.811653] USB Video Class driver (1.1.1)
[ 7.750915] 8021q: 802.1Q VLAN Support v1.8
[ 7.809216] uart-pl011 fe201000.serial: no DMA platform data
[ 7.850039] random: crng init done
[ 7.850062] random: 7 urandom warning(s) missed due to ratelimiting
[ 8.187524] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 8.343838] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 8.840051] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 8.840548] bcmgenet fd580000.ethernet eth0: Link is Down
[ 10.665241] usb 1-1.4: reset high-speed USB device number 4 using xhci_hcd
[ 11.618044] tun: Universal TUN/TAP device driver, 1.6
[ 14.309817] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 15.344484] Bluetooth: Core ver 2.22
[ 15.344582] NET: Registered protocol family 31
[ 15.344597] Bluetooth: HCI device and connection manager initialized
[ 15.344623] Bluetooth: HCI socket layer initialized
[ 15.344643] Bluetooth: L2CAP socket layer initialized
[ 15.344674] Bluetooth: SCO socket layer initialized
[ 15.354510] Bluetooth: HCI UART driver ver 2.3
[ 15.354531] Bluetooth: HCI UART protocol H4 registered
[ 15.354628] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 15.356132] Bluetooth: HCI UART protocol Broadcom registered
[ 16.646736] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[ 18.321157] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 18.321166] Bluetooth: BNEP filters: protocol multicast
[ 18.321179] Bluetooth: BNEP socket layer initialized
[ 30.013940] fuse: init (API version 7.32)
[ 379.141738] blk_update_request: I/O error, dev mmcblk0, sector 533256 op 0x1:(WRITE) flags 0x103000 phys_seg 1 prio class 0
[ 379.141752] Buffer I/O error on dev mmcblk0p2, logical block 97, lost async page write
[ 379.145255] EXT4-fs error (device mmcblk0p2): ext4_check_bdev_write_error:216: comm rs:main Q:Reg: Error while async write back metadata
