ESP32-cam stream not loaded (SOLVED)
ESP32-cam
Stream is not loaded
Octoprint 1.7.2
I configured the Webcam Support:
Webcam-Support enabled
Stream-URL: http://esp32-cam:81/stream
Timelapse-Support activated
Snapshot-URL: http://esp32-cam/capture
Timelapse is working inside Octoprint
Stream displays an error.
If I click on the Streaming-URL (http://esp32-cam:81/stream) in the errormessage, the stream is loaded in a new browserwindow.
Any ideas
Logs:
webcamd.log
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 640x480 -f 10
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video10
/root/bin/webcamd: line 184: printf: 0x: invalid hex number
Nov 27 17:30:30 root: Starting USB webcam
  • It seems that you don't have VL805 (Raspberry Pi 4).
    Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /dev/video10
    i: Using V4L2 device.: /dev/video10
    i: Frames Per Second.: 10
    i: Format............: JPEG
    Error opening device /dev/video10: video capture not supported.
    i: init_VideoIn failed
Goodbye...
SYSLOG:
Nov 27 17:31:55 octopi systemd[1]: webcamd.service: Succeeded.
Nov 27 17:31:55 octopi systemd[1]: Started the OctoPi webcam daemon with the user specified config.
Nov 27 17:31:57 octopi systemd[1]: webcamd.service: Service RestartSec=1s expired, scheduling restart.
Nov 27 17:31:57 octopi systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 2795.
Nov 27 17:31:57 octopi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
Nov 27 17:31:57 octopi systemd[1]: Starting the OctoPi webcam daemon with the user specified config...
Nov 27 17:31:57 octopi root: Starting USB webcam
Nov 27 17:31:58 octopi MJPG-streamer [9946]: starting application
Nov 27 17:31:58 octopi MJPG-streamer [9946]: MJPG Streamer Version: git rev: 5554f42c352ecfa7edaec6fc51e507afce605a34
Nov 27 17:31:58 octopi MJPG-streamer [9946]: Using V4L2 device.: /dev/video10
Nov 27 17:31:58 octopi MJPG-streamer [9946]: Desired Resolution: 640 x 480
Nov 27 17:31:58 octopi MJPG-streamer [9946]: Frames Per Second.: 10
Nov 27 17:31:58 octopi MJPG-streamer [9946]: Format............: JPEG
Nov 27 17:31:58 octopi MJPG-streamer [9946]: TV-Norm...........: DEFAULT
Nov 27 17:31:58 octopi MJPG-streamer [9946]: init_VideoIn failed
Nov 27 17:31:59 octopi systemd[1]: webcamd.service: Succeeded.
Nov 27 17:31:59 octopi systemd[1]: Started the OctoPi webcam daemon with the user specified config.
Nov 27 17:32:00 octopi systemd[1]: webcamd.service: Service RestartSec=1s expired, scheduling restart.
Nov 27 17:32:00 octopi systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 2796.
Nov 27 17:32:00 octopi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
Nov 27 17:32:00 octopi systemd[1]: Starting the OctoPi webcam daemon with the user specified config...
Nov 27 17:32:00 octopi root: Starting USB webcam
Nov 27 17:32:00 octopi MJPG-streamer [9972]: starting application
Nov 27 17:32:00 octopi MJPG-streamer [9972]: MJPG Streamer Version: git rev: 5554f42c352ecfa7edaec6fc51e507afce605a34
Nov 27 17:32:01 octopi MJPG-streamer [9972]: Using V4L2 device.: /dev/video10
Nov 27 17:32:01 octopi MJPG-streamer [9972]: Desired Resolution: 640 x 480
Nov 27 17:32:01 octopi MJPG-streamer [9972]: Frames Per Second.: 10
Nov 27 17:32:01 octopi MJPG-streamer [9972]: Format............: JPEG
Nov 27 17:32:01 octopi MJPG-streamer [9972]: TV-Norm...........: DEFAULT
Nov 27 17:32:01 octopi MJPG-streamer [9972]: init_VideoIn failed
Nov 27 17:32:01 octopi systemd[1]: webcamd.service: Succeeded.
In the browser, you should be able to access the error console. By pressing ctrl-shift-j or F12 (and select 'Console') - those work for Windows/Chrome - you should be able to see if there is an error loading the webcam stream.
Thank you. This helped me to solve the problem.
Chrome blocked the Webcam URL, because of the CORS policy
How to enable ESP32-webcam:
Enter in the address field chrome://flags/#block
-Secure private network requests
change the option to disable disable, and then restart the browser
