I can't seem to figure out how to execute a compiled program from the event hook triggers in configure.yaml.
I have a custom built LED panel that I want to turn on and off with the prints using the RPi's GPIO, which requires a custom library (so enclosure won't work, hence the scripts). I am relatively newer to Linux, so I'm guessing it's a misunderstanding on how to run the shell commands from the octoprint instance due to file permissions?
I have verified that executing the programs from the command line do turn on/off the LEDs (but they do require super user permissions or I get "Can't open /dev/mem: Permission denied") and that all users (chmod a+x) have executable permissions to these executables.
config.yaml snippet
events:
subscriptions:
- command: ~/LED_on
event: PrintStarted
type: system
- command: ~/LED_off
event:
- PrintFailed
- PrintDone
- PrintCancelled
type: system
ls -l
-rwxr-xr-x 1 pi pi 8516 Jul 20 16:54 LED_off
-rwxr-xr-x 1 pi pi 8636 Jul 20 17:03 LED_on
Running latest version of octopi install
