Expanding file system on pi after Octoprint is installed
I am trying to prevent a possible problem
Just want to know if I expand my pi's file system, will this mess up the already installed installation to Octoprint
Looked for a topic on this forum and did a google search with no answer
this does not apply
<sbrowser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/93.0.4577.63 Safari/537.36 Edg/93.0.961.47
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1400
env.hardware.ram: 915718144
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.6.1
printer.firmware: Prusa-Firmware 3.10.0 based on Marlin
mall>You can download this in OctoPrint's System Information dialog ... no bundle, no support!)
It shouldn't, and if you used the octopi image the filesystem is automatically expanded on the first boot.
you can check the partition size with df -h
if it's close to the sd card size then it is probably already expanded (as @jneilliii said)
