I'm trying to get an IP Camera working for OctoLapse Timelapses for my Ender 3.
The app i'm using (IPCamera) has an IP address that can be seen in a regular web browser. I have not been able to make it work on OctoPrint. I have the multi-cam plugin working, and have previously used two usb webcams, however, the phone quality is a better than one of the webcams.
In the Settings > MultiCam options, I've tried adding the IP url provided by the app and it does not work. Under some other forums, I've seen people use a login such as "http://username:password@1.2.3.4/tmpfs/snap.jpg", but I do not have a username or password since it's just an app that streams the camera to an IP URL, rather than an actual IP camera device. Another one I've tried is "http://192.168.0.148/jpg/image.jpg" but no success either. I think the solution would be a similar URL to those, but in the OctoLapse menu, which is slightly different, as it uses a base address. Lastly, since I use two cameras, I have the entire setup from the multi-cam tutorial by Chris Riley, so the secondary camera is set to port 8081.
Logs (/var/log/webcamd.log, syslog, dmesg, ...)
Any information would be greatly appreciated!
Although the iPhone has an IP address, you can't access the iPhone's camera via that IP address. Maybe there is an iPhone App that provides that feature.
Thanks. I tried searching multiple things, but I've been really unlucky, as the majority of the similar posts use an actual IP camera that has a log-in and password, not a phone using an IP app
I wanted to mention this, since your question mentioned Octolapse. The multi-cam plugin settings will not affect Octolapse. To get an IP camera working you will have to edit the Octolapse camera profiles and give it the correct snapshot url. There is a 'test' button there that you can use to check if the URL you provided is working, and delivering a jpg image.
You mentioned that you are able to access the IP camera on your computer browser, but what URL (IP) are you using in your browser to see a snapshot (not a stream/video)?
I don't know how to get a snapshot. The only thing I can see is just a stream feed from the IP address. Do you have any recommendations for a snapshot?
I never got it working. I stuck with my two camera setup which are directly connected to the raspberry pi, but the quality isn't too great. The main issue was that I think the ip address needed some sort of snapshot letters added to the ip address.
I haven’t tryed yet but I was able to talk with the developer of the app and from the browser it works. The url for the pure live stream is XX.XX.XX.XX/live, to get a single snapshot is XX.XX.XX.XX/photo (it opens a webpage with a .jpg) of course assuming you do not have authentication turned on for the app. I am really confident it would work. I’m just waiting to get my old phone back from my old house to test it with octolapse.
Did you tried the Droidcam app? I'm using one iPhone 5s as streaming webcam. Just install and start the app and use this as stream url:
http://[iPhone IP]:4747/video.force?1280×720
That's right. Even though iPhones have IP addresses, they aren't designed to let you access the camera directly like a security camera. There might be apps that offer camera functionality through the app itself, but forget about using an IP address for iPhone camera access.
