Hi there knolegable users and devs. I have upgraded (at the moment it feels like a downgrade) my ole ctc replicator dual and I am slowly learning how to do things the marlin & octoprint way after 6 years of man handling Rep G slicer. Its now running the latest bugfix from 3rd dec customised for the machine with many hours of testing and tweaking on an skr 1.4 turbo with tft35 screen. 3d touch, working neopixels etc. I have just started to get to grips with Octoprint 1.5.1 as I have been using cura 4.8.1 but it is thowing me off trying to print a thinwall & hollow 20x20x20 cube. I used cura to slice the file with spiralized wall and it prints perfect from a usb stick plugged into the tft35 screen (it starts the wall and just keeps going till it reaches the top) as it should do but the same gcode file run from octoprint lays one section of line "one side wall" at a time then moves to the center of the build before moving back to the wall and doing another single side. repeating this over and over . 1 side wall into center, back to wall, 1 side wall, into center. I have spent hours looking for a setting or even a plugin that may be causing it but I have failed. My next move it safemode to see if a plugin is missbehaving and it prints ok. I thought I would ask to see if anyone has come across this before and may save me more pain as I am 100% newbie to Octoprint and "youtubed" best plugins to get me started.
Any advise is welcome
**edit & update **
It hast to be one of the plugins I installed blindly after watching utube vids as safemode is printing perfectly as expected. now to find out who is causing the problem.
Active Filters (0.0.1)
Bed Visualizer (1.0.0)
Firmware Updater (1.7.5)
Floating Navbar (0.3.4)
Navbar Temperature Plugin (0.14)
Octolapse (0.4.1)
PrintTimeGenius Plugin (2.2.6)
Sidebar Webcam (0.1.8)
Simple Emergency Stop (1.0.4)
Tab Order (0.5.12
Terminal Messaging (0.1.0)
Themeify (1.2.2)
