If you have ran already OctoPrint on a printer, you may have noticed that the most of the data are displayed within OctoPrint's GUI.
The temperatures are reported back from the printer, other data is derived from the gcode file.
The coordinates can't be exact because of the input buffer of the printer.
And no, the printer does not report back the actual head position during print.
You can check the REST API documentation for what data is available, including in the push updates over the websocket. If you want to collect any data you cannot already see from these interfaces, you may have to write a custom plugin.
Not sure if feedrate is reported at all - at least I couldn't find a gcode for it
For fan speed you need a fan with tachometer output and a board that supports it - alternatively, you can let Marlin notify you when the speed has been changed.
Realtime coordinates reporting from the planner can be enabled, but can have an impact on the performance of your printer.
You have to enable those options in the Marlin config, compile a new firmware and flash it on your printer if you want to use them.
