I have recently added an MMU2S to my Prusa MK3S+. Works fine on its own using the SD card. I tried updating my profile to add the MMU and the 5 extruders with the "shared nozzle" setting checked, when that didn't work I added a new profile. The new printer profile also has 5 extruders with a shared nozzle selected.
When I take the same Gcode file and use with Octoprint, I get an "Extruder Count Error - Your printer profile has fewer extruders (1) defined than your gcode file (5)."
I tried updating my existing profile for multiple extruders. Then tried adding a new profile which had the multiple extruder settings. Also some updating and restarting. I verified that my old profile still works with single color prints. The printer complains that the file was made for a different type of printer, but I can print single color still via Octoprint.
I also noticed that the Filament Manager plugin shows 5 tools. So it would seem that somewhere Octoprint knows I have 5 possible extrusion possibilities.
octoprint-systeminfo-20210723231525.zip (38.0 KB)
Octoprint version: v1.6.1
OctoPi version: 0.18.0, running on RPi 4B
Printer: Prusa MK3S+ / MMU2S
Firmware: 3.10.0-4481 / MMU2S v1.0.6
Browser: Firefox 90.0.1
OS: Mac OS 11.4
Last bit of info from octoprint.log when I tried to print an MMU gcode file:
2021-07-23 22:51:30,128 - octoprint.printer.standard.job - INFO - Print job selected - origin: local, path: BBQmagnets/MaTE_MMU_0.2mm_PETG_MK3SMMU2S_1h18m.aw.gcode, owner: dad, user: dad
2021-07-23 22:51:30,158 - octoprint.plugins.DisplayLayerProgress - INFO - File '/home/pi/.octoprint/uploads/BBQmagnets/MaTE_MMU_0.2mm_PETG_MK3SMMU2S_1h18m.aw.gcode' selected. Determining number of layers.
2021-07-23 22:51:30,166 - octoprint.plugins.DisplayLayerProgress - INFO - Read total height from MetaFile
2021-07-23 22:51:30,186 - octoprint.util.comm - INFO - Starting job on behalf of user dad
2021-07-23 22:51:30,202 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2021-07-23 22:51:30,211 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: BBQmagnets/MaTE_MMU_0.2mm_PETG_MK3SMMU2S_1h18m.aw.gcode, owner: dad, user: dad
2021-07-23 22:51:30,285 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2021-07-23 22:51:30,828 - octoprint.plugins.DisplayLayerProgress - INFO - Store layer count in MetaFile
2021-07-23 22:51:31,337 - octoprint.util.comm - INFO - Cancelling job on behalf of plugin octolapse
2021-07-23 22:51:31,411 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Cancelling"
2021-07-23 22:51:31,429 - octoprint.printer.standard.job - INFO - Print job cancelled - origin: local, path: BBQmagnets/MaTE_MMU_0.2mm_PETG_MK3SMMU2S_1h18m.aw.gcode, owner: dad, user: None
2021-07-23 22:51:31,509 - octoprint.util.comm - INFO - Changing monitoring state from "Cancelling" to "Printing"
2021-07-23 22:51:31,659 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Operational"
2021-07-23 22:51:31,954 - octoprint.plugins.DisplayLayerProgress - INFO - File select-event processing done!'
2021-07-23 22:51:32,094 - octoprint.plugins.DisplayLayerProgress - INFO - Printing started. Detailed progress started.{'name': 'MaTE_MMU_0.2mm_PETG_MK3SMMU2S_1h18m.aw.gcode', 'path': 'BBQmagnets/MaTE_MMU_0.2mm_PETG_MK3SMMU2S_1h18m.aw.gcode', 'origin': 'local', 'size': 1690977, 'owner': 'dad', 'user': 'dad'}
2021-07-23 22:51:32,137 - octoprint.plugins.DisplayLayerProgress - INFO - Printing stopped. Detailed progress stopped.
2021-07-23 22:51:32,140 - octoprint.plugins.filamentmanager - INFO - Updating Filament usage for octoprint configured toolcount: 5
2021-07-23 22:51:32,140 - octoprint.plugins.filamentmanager - INFO - Filament tracked toolcount: 1
2021-07-23 22:51:32,140 - octoprint.plugins.filamentmanager - INFO - Filament tracked values: [0.0]
2021-07-23 22:51:32,140 - octoprint.plugins.filamentmanager - INFO - Filament used: 0.0 mm (tool0)
2021-07-23 22:51:32,147 - octoprint.plugins.filamentmanager - WARNING - No selected spool for tool0
2021-07-23 22:51:32,451 - octoprint.plugins.tracking - INFO - Sent tracking event print_started, payload: {'origin': 'local', 'file': '03f7d361b2c3f0702e81f65e3ae52bb3798e0a9e'}
2021-07-23 22:51:32,923 - octoprint.plugins.tracking - INFO - Sent tracking event print_cancelled, payload: {'origin': 'local', 'file': '03f7d361b2c3f0702e81f65e3ae52bb3798e0a9e', 'elapsed': 1}
2021-07-23 22:51:33,825 - octoprint.plugins.DisplayLayerProgress - INFO - Printing stopped. Detailed progress stopped.
2021-07-23 22:51:34,540 - octoprint.plugins.tracking - INFO - Sent tracking event print_failed, payload: {'origin': 'local', 'file': '03f7d361b2c3f0702e81f65e3ae52bb3798e0a9e', 'elapsed': 1, 'reason': 'cancelled'}
2021-07-23 22:57:48,654 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-07-23 22:57:57,129 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 6308, 'printer_state': 'OPERATIONAL'}
2021-07-23 23:06:07,874 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:172.16.7.136
