Since the update to 1.5 yesterday ... when I'm printing
The extruder is not moving and do not feed filament to the hotend .
Aside of this , the same Gcode does not behave the same as when started from SD card
as if the start gcode I've set is not fully understood.
As not working from SD ... I thought it was a clog ... I cleaned everything
I decided to start a print from SD ... and "miracle" everything works fine
Complete Logs
Send: N298 G1 X108.03 Y96.725 Z0.3577
Recv: ok
Send: N299 G1 X107.624 Y96.288 Z0.35114
Recv: ok
Send: N300 G1 X107.2 Y95.722 Z0.35119
Recv: ok
Send: N301 G1 X106.485 Y94.591 Z0.35119
Recv: ok
Send: N302 G1 X106.257 Y94.293 Z0.35120
Recv: ok
Send: N303 G1 X106.0 Y94.008 Z0.35121
Recv: ok
Send: N304 G1 X105.712 Y93.74 Z0.3569
Changing monitoring state from "Printing" to "Pausing"
Recv: ok
Send: N305 M40033
Recv: ok
Send: N306 M114*34
Recv: X:105.71 Y:93.74 Z:0.35 E:0.00 Count X:8489 Y:7574 Z:140
Recv: ok
Changing monitoring state from "Pausing" to "Paused"
OctoPrint Version 1.5.0
Version 0.17.0, running on Raspberry Pi 4 Model B Rev 1.1
Printer Geeeteech A20M Marlin 1.1.8
Win10 ( any browser )
