I recently updated a DaVinci 1.0 with Repetier 0.92 firmware to enable OctoPrint and 3rd party filament. Firmware update was successful. File was sliced with Simplify3D version 2.2.2 and uploaded to Octoprint. Upon startup the bed was raised to the max height. The extruder started to move and hit the bed while trying to adjust X and Y positions. Very loud impact and I hope the printer isn't damaged.
To troubleshoot I updated the Slicer to Simplify3D version 4.1.2 and ran into the same error. This print was my first attempt with the Repetier firmware and Octoprint.
Any suggestions would be greatly appreciated. Thanks,
updated to most current version of Simplify3D 4.1.2. Also tried to connect directly with Simplify 3D to isolate problem and was unable to print via direct connect with Simplify 3D as well.
Complete Logs
R
Recv: T:213.16 /220 B:80.61 /80 B@:0 @:230
Recv: busy:heating
Recv: T:213.86 /220 B:80.41 /80 B@:0 @:230
Recv: T:214.74 /220 B:80.20 /80 B@:0 @:230
Recv: ok 10
Send: N11 M105*23
Recv: SelectExtruder:0
Recv: FlowMultiply:100
Recv: ok 11
Recv: T:215.09 /220 B:80.12 /80 B@:0 @:230
Send: N12 G92 E0.0000*90
Recv: ok 12
Send: N13 G1 E-2.0000 F1800*33
Recv: ok 13
Send: N14 G1 Z0.450 F2400*40
Recv: ok 14
Send: N15 G1 X76.637 Y80.882 F3600*119
Recv: ok 15
Send: N16 G1 E0.0000 F1800*11
Recv: ok 16
Send: N17 G92 E0.0000*95
Recv: ok 17
Send: N18 G1 X78.658 Y79.811 E0.1711 F900*48
Recv: ok 18
Send: N19 G1 X121.333 Y79.811 E3.3647*88
Recv: ok 19
Send: N20 G1 X123.353 Y80.881 E3.5358*84
Recv: ok 20
Send: N21 G1 X135.374 Y98.586 E5.1373*95
Recv: ok 21
Send: N22 G1 X135.374 Y101.414 E5.3490*111
Recv: ok 22
Send: N23 G1 X123.353 Y119.119 E6.9504*104
Recv: ok 23
Send: N24 G1 X121.333 Y120.189 E7.1215*102
Recv: ok 24
Send: N25 G1 X78.658 Y120.189 E10.3151*101
Recv: ok 25
Send: N26 G1 X76.637 Y119.118 E10.4863*108
Recv: ok 26
Send: N27 G1 X64.623 Y101.413 E12.0875*109
Recv: ok 27
Send: N28 G1 X64.623 Y98.587 E12.2990*87
Recv: ok 28
Send: N29 G1 X76.637 Y80.882 E13.9002*89
Recv: ok 29
Send: N30 G92 E0.0000*90
Recv: ok 30
Send: N31 G1 E-2.0000 F1800*33
Recv: ok 31
Send: N32 G1 X76.913 Y81.188 F3600*121
Recv: ok 32
Send: N33 G1 E0.0000 F1800*12
Recv: ok 33
Send: N34 G92 E0.0000*94
Recv: ok 34
Send: N35 G1 X78.758 Y80.211 E0.1563 F900*53
Recv: ok 35
Send: N36 G1 X121.234 Y80.211 E3.3350*92
Recv: ok 36
Send: N37 G1 X123.078 Y81.188 E3.4912*92
Recv: ok 37
Send: N38 G1 X134.974 Y98.709 E5.0760*94
Recv: ok 38
Send: N39 G1 X134.974 Y101.291 E5.2693*101
Recv: ok 39
Send: N40 G1 X123.078 Y118.812 E6.8541*100
Recv: ok 40
Send: N41 G1 X121.234 Y119.789 E7.0103*106
Recv: ok 41
Send: N42 G1 X78.758 Y119.789 E10.1890*111
Recv: ok 42
Send: N43 G1 X76.913 Y118.812 E10.3453*108
Recv: ok 43
Send: N44 G1 X65.023 Y101.290 E11.9299*96
Recv: ok 44
Send: N45 G1 X65.023 Y98.710 E12.1230*85
Recv: ok 45
Send: N46 G1 X76.913 Y81.188 E13.7076*86
Recv: ok 46
Send: N47 G92 E0.0000*90
Recv: ok 47
Send: N48 G1 E-2.0000 F1800*47
Recv: ok 48
Send: N49 G1 X80.120 Y85.011 F3600*113
Recv: ok 49
Send: N50 G1 E0.0000 F1800*9
Recv: ok 50
Send: N51 G92 E0.0000*93
Recv: ok 51
Send: N52 M105*16
Recv: ok 52
Recv: T:216.49 /220 B:80.33 /80 B@:0 @:230
Send: N53 G1 X119.872 Y85.011 E2.9749 F765*14
Recv: ok 53
Send: N54 G1 X130.049 Y100.000 E4.3307*110
Recv: ok 54
Send: N55 G1 X119.872 Y114.989 E5.6866*97
Recv: ok 55
Send: N56 G1 X80.120 Y114.989 E8.6614*91
Recv: busy:processing
Recv: ok 56
Send: N57 G1 X69.948 Y100.000 E10.0170*108
Changing monitoring state from "Printing" to "Cancelling"
Recv: ok 57
Send: N58 M108*23
Recv: ok 58
Send: N59 M84*35
Recv: Unknown command:N58 M108
Recv: ok 59
Send: N60 M105*17
Unexpected error while reading serial port, please consult octoprint.log for details: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2793
Please see https://faq.octoprint.org/serialerror for possible reasons of this.
Changing monitoring state from "Cancelling" to "Offline (Error: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2793)"
I am using a XYZ DaVinci 1.0 updated with Repetier firmware version 0.92 and simplify3D version 4.1.2
