I have been using Octoprint for a while and it always worked without issue. Recently I have been starting to get the issue where my printer does not extrude when starting prints from Octoprint. SO i start the print and the X,Y,Z move accordingly but the E just does nothing. It isn't skipping or anything but the gear does not turn.
Here is where the weird things start
When i then stop the print, extrude a bit of material through the controls in Octoprint and start the print again it works without issues. Also when starting the same print from the SD Card it also works properly.
- Reinstalled the latest version of Octoprint
- Only installed the Creality Temp fix and Creality 2x temp fix plugins
- Flashed new Jyers firmware to the printer (before i had the stock Creality Marling Firmware)
- Checked the extruder cable, and checked if it was connected on both sides
- Switched the USB cable between my Pi 3B and the printer
- checked G-code for any weird things and found nothing.
Not yet
N/A
You can download this in OctoPrint's System Information dialog ... no bundle, no support!)octoprint-systeminfo-20211231100807.zip (51.4 KB)
System info bundle is uploaded allong
- OctoPrint 1.7.2
- OctoPi Version 0.18.0, running on Raspberry Pi 3 Model B Plus Rev 1.3
- Printer Ender 3 V2
- Firmware: Jyers E3V2-Default-v4.2.7-v2.0.1.bin
