I can not connect my Pi 3 to my Monoprice MP Mini V2 3D printer.
Changing the cable, spamming Connect button, adding ports, removing ports
Terminal
Serial port list: []
Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
Changing monitoring state from "Error: Failed to autodetect serial port, please set it manually." to "Detecting serial port"
To: Monoprice MP Select Mini V2
Access Point: Orbi Satellite
Operating System: Debian
