Raspberry Pi Camera Module V2-8
The webcam server is currently not running
rebooted, unplugged and re-plugged, reflashed, swapped connector ends, tried different ribbon connector
pi@octopi:~ $ vcgencmd get_camera
supported=1 detected=0
pi@octopi:~ $ /var/log/webcamd.log
-bash: /var/log/webcamd.log: No such file or directory
pi@octopi:~ $ raspistill -o cam.jpg
mmal: Cannot read camera info, keeping the defaults for OV5647
mmal: mmal_vc_component_create: failed to create component 'vc.ril.camera' (1:ENOMEM)
mmal: mmal_component_create_core: could not create component 'vc.ril.camera' (1)
mmal: Failed to create camera component
mmal: main: Failed to create camera component
mmal: Camera is not detected. Please check carefully the camera module is installed correctly
pi@octopi:~ $ lsusb
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Tried posting logs, says "new users can only post 2 links"
Raspberry 4
8 GB SDHC
Octoprint 1.3.12
Octopi 0.17.0
