Installed OctoPrint about two weeks ago and yesterday it suddenly stopped connecting to the WIFI. It works just fine when connected via LAN. On startup it says:
Failed to start "Raise network interfaces"
See systemctl status networking.service for details
When i enter above command i get this:
β networking.service - Raise network interfaces
Loaded: loaded (/lib/systemd/system/networking.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2024-07-15 02:17:26 CEST; 1h 4min ago
Docs: man:interfaces(5)
Process: 258 ExecStart=/sbin/ifup -a --read-environment (code=exited, status=1/FAILURE)
Main PID: 258 (code=exited, status=1/FAILURE)
CPU: 13ms
Jul 15 02:17:25 forsenprint systemd[1]: Starting Raise network interfaces...
Jul 15 02:17:25 forsenprint ifup[258]: ifup: /etc/network/interfaces:1: misplaced option
Jul 15 02:17:25 forsenprint ifup[258]: ifup: couldn't read interfaces file "/etc/network/interfaces"
Jul 15 02:17:26 forsenprint systemd[1]: networking.service: Main process exited, code=exited, status=1/FAILURE
Jul 15 02:17:26 forsenprint systemd[1]: networking.service: Failed with result 'exit-code'.
Jul 15 02:17:26 forsenprint systemd[1]: Failed to start Raise network interfaces.
Checked if the USB WIFI stick is broken, but works with my PC.
Tried to connect it to a different WIFI signal (2.4GHz and 5GHz) by editing the "octopi-wpa-supplicant.txt" file with Notepad++.
Checked for updates for OctoPrint
Did update/upgrade as suggested in this thread.
Followed these steps from this thread:
Yes.
octoprint-systeminfo-20240715024311.zip (283.5 KB)
Model: Raspberry Pi 2 Model B
Versions:
OctoPi: 1.0.0 (build 2024.06.18.085851)
OctoPrint: 1.10.2
Python: 3.9.2
USB WIFI Stick: Edimax 150mbps wireless 802.11bgn nano usb adapter
