Updated to OctoPrint 1.8.7 this morning via the webUI and it didn't come back up.
Mar 3 09:47:43 octopi systemd[1667]: octoprint.service: Failed to execute command: Exec format error
Mar 3 09:47:43 octopi systemd[1667]: octoprint.service: Failed at step EXEC spawning /home/pi/oprint/bin/octoprint: Exec format error
Mar 3 09:47:43 octopi systemd[1]: octoprint.service: Main process exited, code=exited, status=203/EXEC
Mar 3 09:47:43 octopi systemd[1]: octoprint.service: Failed with result 'exit-code'.
Turns out /home/pi/oprint/bin/octoprint was zero bytes. There was plenty of disk space so that wasn't the issue.
~/oprint/bin/pip install --ignore-installed OctoPrint
Now i have a non-zero byte OctoPrint - which leads to another problem:
Could not initialize environment detector: version conflict: '/home/pi/oprint/lib/python3.7/site-packages/psutil/_psutil_linux.cpython-37m-arm-linux-gnueabihf.so' C extension module was built for another version of psutil (5.8.0 instead of 5.9.4); you may try to 'pip uninstall psutil', manually remove /home/pi/oprint/lib/python3.7/site-packages/psutil/_psutil_linux.cpython-37m-arm-linux-gnueabihf.so or clean the virtual env somehow, then reinstall
I tried:
~/oprint/bin/pip install --ignore-installed psutil to
won't start so can't get to safe mode
NO
It won't even start, cant get this far.
Raspberry Pi 3b that was initially built with the Pi imager and has been working fine for 3-ish years.
At this point I'm thinking to just re-image the Pi?
