Fanspeed, Position extruder data in Python with REST API
I cannot manage to get the current fanspeed, feedrate and position of the extruder head with REST API in Python. I read on some forums that this is not possible but I was wondering if there is any other/new way to get this data. The goal in the end is to collect as many printer variables as possible while printing to do some analysis.
I managed to get the temperature data of the extruder and the bed with REST API and I can post commands for the fanspeed for example.
I use Octoprint with my laptop connected to a Prusa MK3s
This is actually covered in the very documentation of the API endpoints:
Thanks for your answer! Do you know what python code to use for push updates? I cannot find any code
There's a basic client available on the command line:
$ octoprint client --help
Usage: octoprint client [OPTIONS] COMMAND [ARGS]...
  Basic API client.
Options:
  -a, --apikey TEXT
  -h, --host TEXT
  -p, --port INTEGER
  --httpuser TEXT
  --httppass TEXT
  --https
  --prefix TEXT
  --help              Show this message and exit.
Commands:
  command         Sends a JSON command to the specified server path.
  delete          Sends a DELETE request to the specified server path.
  get             Performs a GET request against the specified server path.
  listen
  patch_json      PATCHes JSON data to the specified server path.
  post_from_file  POSTs JSON data to the specified server path, taking the...
  post_json       POSTs JSON data to the specified server path.
  upload          Uploads the specified file to the specified server path.
The listen sub command is a basic push socket client that simply logs what it receives. The socket client is implemented in octoprint_client.Client#create_socket.
