I get the "Octoprint is currently not running" webpage when I try to access my printer. The log file says "name '_urllib_response_moved_attributes' is not defined", and when I rebooted, I get a new error of "bad marshal data (unknown type code)"
Is there any way to fix this, or should I just get a new SD card and start from scratch? Not sure if this is a failing card; I haven't tested the SD card yet.
Reboot several times
Tried restarting the octoprint service
no; can't even start octoprint
n/a
I get the same fatal errors when trying to generate the dump from the commandline
Pi4, running OctoPi 0.18.0 and OctoPrint 1.6.1
