Since the last update of my OctoPi, the filiament calculator no longer works.
I get the following error message:
Does anyone have an idea where I should look to fix the error?
The PrintTimeGenius plugin has also stopped working properly since then (it no longer calculates the time after uploading).
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/95.0.4638.69 Safari/537.36
connectivity.connection_check: 192.168.2.96:53
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1400
env.hardware.ram: 914001920
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.python.pip: 21.0.1
env.python.version: 3.7.3
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.7.2
printer.firmware: Marlin 1.1.0-RC8 (Github)
Hello @FreundderNacht !
As you are running OctoPrint 1.7.2, you should have seen this:
So could you please upload the bundle into the next post not just the systeminfo.
sorry, I thought I had uploaded it.
Here is my system info:
octoprint-systeminfo-20211103190316.zip (209.1 KB)
Please try in safe mode.
You should get a filament amount like this:
What slicer are you using?
I use the latest version of Cura as a slicer.
I will try out the SafeMode, but it might take until Friday before I can give feedback.
I have now started Octoprint in save mode. Since all plug-ins are deactivated here, I could not find anything wrong.
I have also uninstalled and reinstalled the Printtimegenius plugin.
Unfortunately without success
I also deactivated and activated the Spool Manager.
Unfortunately without success.
At the moment the PrinttimeGenius is not working and the Spoolmanger is not working properly.
I have made a debug log of the Printtimegenius:
2021-11-04 19:03:11,807 Start von PrintTimeGenius
2021-11-04 19:07:21,046 Die integrierte Analyse wird nicht ausgeführt.
2021-11-04 19:07:21,047 Deaktiviert: "/home/pi/oprint/bin/python3" "/home/pi/oprint/lib/python3.7/site-packages/octoprint_PrintTimeGenius/analyzers/analyze_gcode_comments.py" "/home/pi/.octoprint/uploads/Untersetzer/Untersetzer Ø120_PLAplus-schwarz.gcode"
2021-11-04 19:07:21,047 Läuft: "/home/pi/oprint/bin/python3" "/home/pi/oprint/lib/python3.7/site-packages/octoprint_PrintTimeGenius/analyzers/analyze_progress.py" marlin-calc "/home/pi/.octoprint/uploads/Untersetzer/Untersetzer Ø120_PLAplus-schwarz.gcode" ""
2021-11-04 19:07:34,266 Fehler beim Ausführen von '"/home/pi/oprint/bin/python3" "/home/pi/oprint/lib/python3.7/site-packages/octoprint_PrintTimeGenius/analyzers/analyze_progress. py" marlin-calc "/home/pi/.octoprint/uploads/Untersetzer/Untersetzer Ø120_PLAplus-schwarz.gcode" ""'
Traceback (letzter Anruf zuletzt):
Datei "/home/pi/oprint/lib/python3.7/site-packages/octoprint_PrintTimeGenius/__init__.py", Zeile 337, in _do_analysis
results_err = sarge_job.stderr.text
Datei "/home/pi/oprint/lib/python3.7/site-packages/sarge/__init__.py", Zeile 275, im Text
return self.bytes.decode(self.encoding)
UnicodeDecodeError: 'utf-8' Codec kann Byte 0xd8 in Position 275 nicht dekodieren: ungültiges Fortsetzungsbyte
2021-11-04 19:07:34,303 Deaktiviert: "/home/pi/oprint/bin/python3" "/home/pi/oprint/lib/python3.7/site-packages/octoprint_PrintTimeGenius/analyzers/analyze_gcode_comments.py" "/home/pi/.octoprint/uploads/Untersetzer/Untersetzer Ø120_PLAplus-schwarz.gcode" --parsers slic3r_pe_print_time slic3r_pe_print_time_remaining
2021-11-04 19:07:35.391 Integrierte Analyse wird nicht ausgeführt.
2021-11-04 19:07:35.398 Deaktiviert: "/home/pi/oprint/bin/python3" "/home/pi/oprint/lib/python3.7/site-packages/octoprint_PrintTimeGenius/analyzers/analyze_gcode_comments.py" "/home/pi/.octoprint/uploads/Untersetzer/Untersetzer Ø120_PLA-Glow_in_the_dark.gcode"
2021-11-04 19:07:35,404 Läuft: "/home/pi/oprint/bin/python3" "/home/pi/oprint/lib/python3.7/site-packages/octoprint_PrintTimeGenius/analyzers/analyze_progress.py" marlin-calc "/home/pi/.octoprint/uploads/Untersetzer/Untersetzer Ø120_PLA-Glow_in_the_dark.gcode" ""
2021-11-04 19:07:48,675 Fehler beim Ausführen von '"/home/pi/oprint/bin/python3" "/home/pi/oprint/lib/python3.7/site-packages/octoprint_PrintTimeGenius/analyzers/analyze_progress. py" marlin-calc "/home/pi/.octoprint/uploads/Untersetzer/Untersetzer Ø120_PLA-Glow_in_the_dark.gcode" ""'
It shows an error, I just can't assign it.
You may raise an issure report at the authors github:
system
Closed
9
