After update marlin and octoprint Filament runout (m600) causes timeout in octoprint.
When change filament print fail for M112 command.
Before in terminal I had Recv: echo:busy: paused for user
and everything worked
Now I don't have the message anymore
Reinstall Marlin with host action command enabled. No success
Reboot Rpi. No success.
Reinstall Octoprint at latest version. Not success
TERMINAL TAB
When the filament run outs or M600 command
Recv: ok
Send: N129 M117 ETL 08h46m37s*11
Recv: //action:notification 0.22p complete
Recv: ok
Send: N130 M117 ETA 22 13 31 Day 29*33
Send: N131 M117 Good accuracy*25
Send: N132 M117 0.22p complete*99
Send: N133 M117 ETL 08h46m37s*0
Send: N134 M117 ETA 22 14 11 Day 29*32
// From here the head was in parking position waiting for filament change (before,when the runout senser worked correctly i had a message in octoprint which requeest user action but now i dont have anymore)
Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
//At this point the filament is reloaded
Recv: ok
Send: N154 M117 Good accuracy*26
Send: N155 M117 0.22p complete*98
Send: N156 M117 ETL 08h46m37s*3
Send: N157 M117 ETA 22 14 51 Day 29*33
Send: N158 M117 Good accuracy*22
Send: N159 M117 0.22p complete*110
Send: N160 M117 ETL 08h46m37s*6
Recv: Error:checksum mismatch, Last Line: 100
Recv: Resend: 101
Printer requested line 101 but no sufficient history is available, can't resend
Changing monitoring state from "Printing" to "Error: Printer requested line 101 but no sufficient history is available, can't resend"
Send: M112
Send: N161 M112*39
Send: N162 M104 T0 S0*36
Send: N163 M140 S0*97
Changing monitoring state from "Error: Printer requested line 101 but no sufficient history is available, can't resend" to "Offline (Error: Printer requested line 101 but no sufficient history is available, can't resend)"
Closing down send loop
octoprint.log (65.6 KB)
SERIAL LOG
serial(1).log (99.1 KB)
Octoprint Latest Version,Octopi Latest Version, Ender 3 With SKR motherboard, Marlin 2.0.5.3 , Mac Os, Windows 10, Tried with different browser.
The issues happen also with M600 command from LCD printer(change filament)
In the log i triggered 2 times the runout. First time i mantained runout triggered (no filament load) end octoprint not send M112 but (correctly) try to change filament another time)
The second time i simulate the sensor loaded and at the moment of resume printing Octoprint Send M112.
If i try to command M600 when not in printing M112 not appears
