Since I successfully downloaded the last suggested upgrade, Firmware Update 1.13.2, when I print anything, using Octoprint, the filament won't feed, the feeder just sits there. If I put the same Gcode file directly on my Ender micro SD card and print. It works fine, the feeder works when I extrude or retract using the printers panel. Before the upgrade, everything worked great.
Checked all the settings in Cura and Octoprint, Cleaned the nozzle, checked the filament and feeder, all work fine from the printer, but not from the Octoprint program. Gcode files load into Octoprint and everything works as usual except the feeder doesn't feed.
Yes
Yes
browser.user_agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_16) AppleWebKit/605.1.15 (KHTML, like Gecko)
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1400
env.hardware.ram: 915718144
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.throttle_state: 0x80000
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.7.3
printer.firmware: Marlin Ver 2.0.1.4
Octoprint 1.7.3, Firmware Update 1.13.2, Ender 3 Pro, Raspberry Pi 3 +, Mac mini 2018, 3Ghz 6-Core Intel Core I5, Mainboard - Marlin 2.0.6, Motherboard - 4.2.7 - Silent (TMC2225 standalone Mode), Version 2.3, Touch screen panel, Filament runout sensor, Ultimaker Cura slicer,
