after upgrade to latest (17.0) and also installd new plugin UI Cosumize, Filament Manager disapered.
It stat installed in plugin manager and I can "chenge" setting for it etc but whwn running Octopi there is no filament manager so I cant change spool wich means that the print-job wont start due to filament manager saying "not enogh filament for printjob"
after more testing (enable/disable plugins etc.) I manage to shut down UI Custom and have the "old" look in the UI (with Filament manager wich seams to work) but still wont start print job, when in terminal I see M73 P0 "unknown command". Disable "M73 progress" plugin, still same
Is ther a way to revert to the previus Octopi versin ?
We aren't mind readers, logs are the way. Sadly you deleted the template prefilled when you opened this post, instead actively not posting the relevant information.
