As I'm not seeing this Issue raised on the GitHub repository for Prusa MMU, I thought I would post this in here to a wider audience.
When I start a print from a file stored on the Raspberry Pi, with the plug-in Prusa MMU enabled, the nozzle and bed begin heating to the set temps (215/60). Once those temperatures have been reached, the Prusa MMU plugin pops up a dialogue box asking which filament to use.
Once I select the required filament, the printer immediately goes into homing and bed levelling (BL) without loading any filament. When the BL is complete, the printhead rises up and moves to the front right in order to do a filament reload/change. However, there is no filament loaded and when I press the printer button to confirm filament has been removed, the printer asks which filament to load. It then loads the selected filament and the print carries on as normal.
Previously, the Prusa MMU plug-in would bring up the dialogue asking for a filament shortly after starting the print, before the set temperatures had even been reached, and the filament would load as normal once the set temperatures were achieved.
Did you try Safe Mode?
Yes
Did Safe Mode solve the problem?
Yes
Since the issue has only starting happening recently (within the last month or so, hard to tell as I don't run my printers every day), I checked back to see what changes I had made, and the only 2 plug-ins that were updated recently were the Prusa MMU plug-in itself, and the Slicer Thumbnails plug-in.
I disabled the Slicer Thumbnails plug-in - this initially seemed to solve the issue. However, the problem returned after another Octoprint restart.
I manually checked the operation of the 2 filament sensors and they both triggered correctly, and they both show 0 when the homing and BL starts. I also checked that there was nothing obstructing the sensors.
I rolled the Prusa MMU plug-in back to the 2023-10-1, the 2023-9-16 and the 2023-2-26 versions in turn, and the problem still remained. It had previously worked fine with the earlier versions, but I don't think it ever worked with the latest, current version.
I then disabled the Prusa MMU plug-in, and the printer worked correctly.
- Prusa Mk3S+ (FW 3.13.0) plus MMU2S (FW 3.0.0)
- OctoPi 1.0.0cam (build 2023.05.23.124648) on Raspberry Pi 3B+
- Octoprint 1.9.3 (same problem with 1.9.2)
- Python 3.9.2
Plugins installed
Cancel Objects (0.4.7) (disabled)
Dashboard (1.19.10)
DisplayLayerProgress Plugin (1.28.0)
OctoPod Plugin (0.3.15)
PrintTimeGenius Plugin (2.3.1)
Prusa MMU (2023.10.7)
Slicer Thumbnails (1.0.3)
SpoolManager Plugin (1.8.0)
UI Customizer (0.1.9.8)
WebcamTab (0.3.1)
Windows 11 Pro 22H2 OS Build 22621.2428
octoprint-systeminfo-20231016151821.zip (196.9 KB)
Sample G-Code file
2_x_pin_sculpfun_0.2mm_Esun PLA - Silver_42m.gcode (1.2 MB)
I've removed the thumbnail codes blocks.
Thank you advance for any help.
