The Filament (Tool 0) Length as reported in OctoPrint is incorrect when compared to Simplify3D.
I basically trust S3D calculated usage as I have measured out that length of filament before on previous prints, and it comes in pretty close - whereas the length reported in OctoPrint is usually half of actual.
I have read through numerous posts here and Google for solutions, and many recommend setting the filament size in OctoPrint to fix this. However, I cannot find that setting anywhere - and I have looked though all the basic settings (not any of the plugins I have added - I will look there next)
I have run it in safe mode and the Filament (Tool 0) length is correct (matches S3D) at 4.78m. However there is no volume calculation (cm3). So I'm assuming that is done with a separate plugin that was disabled in Safe Mode. Question is: which one?
It did, but creates a new question: Who/what is calculating the Wrong filament length and is it the same plugin that also calculates the print volume?
Complete Logs
Log is attached as a zip:
octoprint (1).zip (48.7 KB)
OctoPrint 1.5.3
Python 2.7.16
OctoPi 0.17.0
I have two other printers running the same version of OctoPrint with the same plugins and versions and their Filament (Tool 0) Length matches S3D.
I have also verified that the filament diameter, as set in Marlin, and reported with M503 is 1.75 in all three printers.
Recv: echo:; Filament settings: Disabled
Recv: echo: M200 S0 D1.75
what is also odd, is the volume calculation (cm3) number matches the filament length...
Attached are screenshots of the issue:
OctoPrint Reported Filament Length:
Simplify3D Reported Length:
Simplify3D gCode Calculated Length:
Simplify3D gCode Filament Diameter:
