FilamentManager Plugin install issue / Windows
Installation of FilamentManager Plugin on a Windows setup "fails" => successful installation messages, but plugin isn't found / visible after OctoPrint restart.
  • Installing manually from command line
  • Switching Octoprint from official 1.4.2 to 1.5.0rc3 to try to install through UI
  • installing the dev version of the plugin (0.5.3, previous github repo) instead of the official one on "new" repo OllisGit.
The latter provides this message, thus I kept trying installing the official release
I didn't, since it's about a plugin.
Complete Logs
Full Logs: octoprint.log (307.8 KB)
UI Install: Success message but plugin is named "Unknown" + error in console logs
Manual install: Success message
Both install methods provide the same result: plugin isn't found
Octoprint 1.4.2 => 1.5.0rc3
Win10 / Edge
Python 3.9.0 / pip 20.2.4
I'm trying to install this FilamentManager plugin as a dependency of PrintJobHistory
Thanks for your help or advice to get clean Print logs on a Windows Octoprint setup
Hello @Nagash!
I assume you uninstalled the obsolete version beforehand?
Hi @Ewald_Ikemann,
Yes indeed, I uninstalled from CLI the previous version each time, since I can't see it in the UI
Looks like a problem in a dependency of the plugin, that is incompatible with Python 3.8 and newer, you are running 3.9. From octoprint.log:
File "c:\octoprint\venv\lib\site-packages\octoprint_filamentmanager\__init__.py", line 17, in <module>
    from .data import FilamentManager
  File "c:\octoprint\venv\lib\site-packages\octoprint_filamentmanager\data\__init__.py", line 13, in <module>
    from sqlalchemy.engine.url import URL
  File "c:\octoprint\venv\lib\site-packages\sqlalchemy\__init__.py", line 9, in <module>
    from .sql import (
  File "c:\octoprint\venv\lib\site-packages\sqlalchemy\sql\__init__.py", line 8, in <module>
    from .expression import (
  File "c:\octoprint\venv\lib\site-packages\sqlalchemy\sql\expression.py", line 33, in <module>
    from .visitors import Visitable
  File "c:\octoprint\venv\lib\site-packages\sqlalchemy\sql\visitors.py", line 28, in <module>
    from .. import util
  File "c:\octoprint\venv\lib\site-packages\sqlalchemy\util\__init__.py", line 8, in <module>
    from .compat import callable, cmp, reduce,  \
  File "c:\octoprint\venv\lib\site-packages\sqlalchemy\util\compat.py", line 172, in <module>
    time_func = time.clock
AttributeError: module 'time' has no attribute 'clock'
From the Python 3.7 time documentation
time.clock()
Deprecated since version 3.3, will be removed in version 3.8
The dependency SQLAlchemy is probably pinned that low for Python 2 compatibility (although I haven't looked), I recommend opening an issue on the github repository so that @OllisGit is aware and can fix it.
Hi @Charlie_Powell ,
thx a lot for analysing the issue!!!
It doesn't look so good, it will take a lot of effort to make the plugin Python 3.8 ready.
For the records here is the plugin-issue link:
No worries, that's what we're here for :grinning_face_with_smiling_eyes:
I know I am turning up an ancient thread but was this ever resolved? Having the same issue now. Thanks
For this thread is not marked as solved, it obviously is not solved.
Also, over 3 years later, things have changed a lot.
So please open a new thread with all requested information.
probably python 3.10 compatibility issue. there is a fork that supposedly works fine. copy/paste this URL in plugin manager > get more > ...from URL.
https://github.com/bitsy-ai/OctoPrint-FilamentManager/archive/refs/heads/fix-python-10-compat.zip
Thank you! I can confirm this works.
