using either octolapse or the built in timelapse
when the job finishes it always adds "Failed" to the front of the file name.
Please upload the octoprint.log so we can check what's going wrong
Try to run with the plugin "Exclude Region" disabled.
i uninstalled exclude region, same erroroctoprint.log (40.0 KB)
Clearly it did not fail, and all the videos work>
You already tried safe mode?
will octolapse work in Safe mode
i will try
nothing works in safe mode, i cannot test it
double checked ...all software is up to date
