File upload button does not open a file browser so that the user can select a file to print
The problem started when I upgraded my OS to Ubuntu 22.04.1 LTS. the following is the output from lsb_release -a:
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 22.04.1 LTS
Release: 22.04
Codename: jammy
I reinstalled the operating system on the pi. I used Raspberry Pi Imager v1.7.2. I am using a 16GB SD card.
Yes, I started OctoPrint in safe mode and the problem still exists.
no
browser.user_agent: Mozilla/5.0 (X11; Linux x86_64; rv:102.0) Gecko/20100101 Firefox/102.0
connectivity.enabled: false
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1400
env.hardware.ram: 914006016
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.octopiuptodate_build: 0.18.0-1.8.2-20220816135025
env.plugins.pi_support.throttle_check_enabled: true
env.plugins.pi_support.throttle_check_functional: true
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: true
octoprint.last_safe_mode.date: 2022-08-28T17:06:08Z
octoprint.last_safe_mode.reason: settings
octoprint.safe_mode: false
octoprint.version: 1.8.2
printer.firmware: Marlin E3V2-Extensible-UI (Jun 6 2021 13:54:38)
systeminfo.generated: 2022-08-28T17:16:43Z
I have used OctoPrint for a few years and have never ran across this problem before. It almost acts like a permissions problem, but, I do not know where to start to troubleshoot. Thank you.
