I have a Flsun super racer
I put a smartphone samsung s8+ connected by cable where I installed octoprint
I use an sd card (fat32) inside my sr
but filename views are bad....
is there a solution? manytimes I don't recognize the file to print if I did not see the complete name
thanks
You could try this plugin:
If that does not fix what you are having an issue with, you are going to have to be more specific than "views are bad".
              yesssss it works!! thanks!
                system
                  Closed
              4
