I want to make a copy of firmware before I flash a new firmware.
Avrdude installed but it cannot read flash. This via PuTTY / RPi
Additional information about your setup (OctoPrint version, OctoPi version, printer, firmware, octoprint.log
, serial.log
or output on terminal tab, ...)
What is the correct command for this as this one will not work
sudo avrdude -p atmega1284p -c arduino -P /dev/ttyUSB0 -b 57600 -F -U flash:r:flash_backup_file.hex
This is the error message I get. Wanhao i3 = Meltzi
pi@octopi:~ $ sudo avrdude -p atmega1284p -c arduino -P /dev/ttyUSB0 -b 57600 -F -U flash:r:flash_backup_file.hex
[sudo] password for pi:
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9705 (probably m1284p)
avrdude: reading flash memory:
Reading | | 0% 0.00s
avrdude: stk500_paged_load(): (a) protocol error, expect=0x10, resp=0xef
avrdude: stk500_cmd(): programmer is out of sync
avr_read(): error reading address 0x0000
read operation not supported for memory "flash"
avrdude: failed to read all of flash memory, rc=-2
avrdude: safemode: Sorry, reading back fuses was unreliable. I have given up and exited programming mode
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x4a
avrdude done. Thank you.
As I know, you can't read the firmware form the board.
OK, is it that bad. So there is overhanging risk that trying to flash new firmware can go south.
So what does this say ??
pi@octopi:~ $ sudo avrdude -P /dev/ttyUSB0 -b 57600 -c arduino -p m1284p -v
avrdude: Version 6.3-20171130
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/etc/avrdude.conf"
User configuration file is "/root/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB0
Using Programmer : arduino
Overriding Baud Rate : 57600
AVR Part : ATmega1284P
Chip Erase delay : 55000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 128 0 no 4096 8 0 9000 9000 0xff 0xff
flash 65 10 256 0 yes 131072 256 512 4500 4500 0xff 0xff
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.16
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: safemode: lfuse reads as 0
avrdude: safemode: hfuse reads as 0
avrdude: safemode: efuse reads as 0
avrdude: safemode: Fuses OK (E:00, H:00, L:00)
Something fishy going on here, now suddenly my previous syntax works.
Reading | ################################################## | 100% 0.01s
Reading | ################################################## | 100% 38.99s
avrdude: writing output file "flash_backup_file.hex"
pi@octopi:~ $ sudo find / -name *.hex
/home/pi/flash_backup_file.hex
In many cases, you're supposed to be able to read most of the different parts of memory from the Arduino chip. (In a few cases, the lock bit has been set so that you can't.)
Sometimes, it's necessary to unplug/re-plug the USB cable once for this to work. I think it's effectively similar to pressing the RESET button in that the board is freshly powered and is more willing to give up the information. They're finicky like that. I'm guessing that once the serial connection has been opened and a START command sent from the host it now doesn't want to allow you to back anything up. So maybe the trick is to boot it up and then go for it.
flash: sudo avrdude -c arduino -P /dev/ttyUSB0 -p m1284p -b 57600 -F -U flash:r:flash_backup_file.hex:r
eeprom: sudo avrdude -c arduino -P /dev/ttyUSB0 -p m1284p -b 57600 -F -U eeprom:r:eeprom_backup_file.hex:r
hfuse: sudo avrdude -c arduino -P /dev/ttyUSB0 -p m1284p -b 57600 -F -U hfuse:r:hfuse_backup_file.hex:r
lfuse: sudo avrdude -c arduino -P /dev/ttyUSB0 -p m1284p -b 57600 -F -U lfuse:r:lfuse_backup_file.hex:r
efuse: sudo avrdude -c arduino -P /dev/ttyUSB0 -p m1284p -b 57600 -F -U efuse:r:efuse_backup_file.hex:r
It wouldn't surprise me if it could talk faster (-b 115200
) than what you're trying.
I normally bring up the Arduino IDE software from Arduino.cc, configure the board type, etc and then verify the Board Info as returned from the chip. You can use this information to slightly change the avrdude configuration if necessary.
I just pulled my flash with the following (noting that I've got a Robo 3D ROBOmainboard that's based on an Arduino Mega 2560 via a straight serial cable connection without an FTDI chip'd cable/dongle/programmer/whatever):
avrdude -c avrispmkII -P /dev/cu.usbmodem14201 -b 115200 -p ATmega2560 -U flash:r:backup_flash.bin:r
