Initially the filament wouldn't extrude when sent from Octoprint, so I started just putting the files on a card and just monitoring from Octoprint. now the Logitech C270 HD Webcam has stopped working as well and I can't send files or monitor.
Safe Mode
Yes
Performing autodetection with 7 port/baudrate candidates: /dev/ttyUSB0@115200, /dev/ttyUSB0@250000, /dev/ttyUSB0@230400, /dev/ttyUSB0@57600, /dev/ttyUSB0@38400, /dev/ttyUSB0@19200, /dev/ttyUSB0@9600
Trying port /dev/ttyUSB0, baudrate 115200
Connecting to port /dev/ttyUSB0, baudrate 115200
Handshake attempt #1 with timeout 2.0s
Connected to: Serial<id=0xad3b6310, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0*125
Handshake attempt #2 with timeout 2.0s
Recv: ùNþ\x00OéAà\x9bxn>\x9aI\ip|P.\x00M\x93\x88RAt-\x1c.tY:Á6i@áBøn\x9b\x10:ðX\x9a@áB\x13\x13\x9ffð!\x12\x086\x93U\x93'\x97ð%Qþ>ñq\x7f\x9f6Aø\x08W~&1\x17\x12
WARNThe received line contains at least one null byte character at position 3, this hints at some data corruption going on
Handshake attempt #3 with timeout 2.0s
Trying port /dev/ttyUSB0, baudrate 250000
Recv: áN\x93\x13:\x17z_&\x13ì!\x10'\x978R\xffÜ=ò6ù}rF\x1fø\x17\x1a\x93&\x93ø6ø>ø2øecho:Unknown command: "\x18"
Recv: ok P15 B7
Changing monitoring state from "Detecting serial connection" to "Operational"
Recv: ok N0 P15 B7
Recv: ok N0 P15 B7
Send: N1 M115*39
Recv: FIRMWARE_NAME:Marlin V2.0.9.3C (Jan 17 2022 11:28:48) SOURCE_CODE_URL:https://marlinfw.org/meta/download/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:CR10 V3 EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
Recv: Cap:SERIAL_XON_XOFF:0
Recv: Cap:BINARY_FILE_TRANSFER:0
Recv: Cap:EEPROM:1
Recv: Cap:VOLUMETRIC:1
Recv: Cap:AUTOREPORT_POS:0
Recv: Cap:AUTOREPORT_TEMP:1
Recv: Cap:PROGRESS:0
Recv: Cap:PRINT_JOB:1
Recv: Cap:AUTOLEVEL:1
Recv: Cap:RUNOUT:1
Recv: Cap:Z_PROBE:1
Recv: Cap:LEVELING_DATA:1
Recv: Cap:BUILD_PERCENT:1
Recv: Cap:SOFTWARE_POWER:0
Recv: Cap:TOGGLE_LIGHTS:0
Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
Recv: Cap:EMERGENCY_PARSER:1
Recv: Cap:HOST_ACTION_COMMANDS:1
Recv: Cap:PROMPT_SUPPORT:1
Recv: Cap:SDCARD:1
Recv: Cap:REPEAT:0
Recv: Cap:SD_WRITE:1
Recv: Cap:AUTOREPORT_SD_STATUS:1
Recv: Cap:LONG_FILENAME:1
Recv: Cap:EXTENDED_M20:1
Recv: Cap:THERMAL_PROTECTION:1
Recv: Cap:MOTION_MODES:0
Recv: Cap:ARCS:1
Recv: Cap:BABYSTEPPING:1
Recv: Cap:CHAMBER_TEMPERATURE:0
Recv: Cap:COOLER_TEMPERATURE:0
Recv: Cap:MEATPACK:0
Recv: Cap:CONFIG_EXPORT:0
Recv: ok N1 P15 B7
Send: M21
Recv: echo:SD card ok
Recv: ok P15 B7
Send: M155 S2
Recv: ok P15 B7
Send: M876 P1
Recv: ok P15 B7
Send: M27 S1
Recv: ok P15 B7
Send: M20 L
Recv: Begin file list
Recv: CAT-35~1.GCO 34578026 cat-3.5H.gcode
Recv: DOG-25~1.GCO 12470129 dog-2.5H.gcode
Recv: PIG-4H~1.GCO 19286323 pig-4H.gcode
Recv: echo:Cannot open subdir AMD64
Changing monitoring state from "Operational" to "Starting"
Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
No response from printer after 6 consecutive communication timeouts, considering it dead. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
Changing monitoring state from "Starting" to "Offline after error"
OctoPrint : 1.7.3
Firmware Check Plugin : 2021.10.11
File Check Plugin : 2021.2.23
Pi Support Plugin : 2022.3.28
CR10 V3
Running from Chrome 99.0.4844.84 on a Mac
Connected to a Raspberry Pi 400 via USB
initially was having issues where files being sent from Octoprint would seemingly send, but the printer wouldn't extrude at all, but the printer
